I have autonomous programmed and the code is built to the robot. I am trying to run my autonomous, but the normal drop down isnt working to select, so i cant actually do anything. Any ideas
Can you share your code? What dashboard are you using, Shuffleboard?
I am using the regular labview dashboard. My code is also the exact same as some code online, so it shouldnt be that. I don’t know how to upload code otherwise
Sorry, I can’t help you with LabView. Someone else will have to jump in.
The autonomous list on the Dashboard gets populated from your roboRIO code.
Check that Robot Code has a green status on the Driver Station.
Then check your Auto List in Begin.vi. That’s where the list comes from.
