We are currently using the REV Color Sensor V3. We were using the example code given on the Rev website for FRC and tested it on RED CARGO. What we found fascinating was that the RGB values we were getting were R: 140 G:80 B:27 or in decimal .56,.32,.10 respectively with an IR value of 296 ish. I was wondering if yall had any reasoning behind why that was the case?
The MXP I2C port outputs 5V while the normal rio I2C port outputs 3.3V. The extra power makes the white LED a lot brighter which can affect color readings. I reccomend just testing and then documenting the values you get from red and blue balls.
In our tests of the color sensor, we got similar values: 0.4, 0.4, 0.2 for red, and 0.2, 0.45, 0.34 for the blue cargo. They were different enough to detect red cargo as red and blue cargo as blue, but when thereâs no cargo, the background was also detected as âredâ.
So weâre trying to put something like black felt into the âbackgroundâ to also detect âno cargoâ.
Color, and the way computers interpret color is a fascinating topic that can go fairly in depth. Fortunately you donât need anything complex, since weâre only comparing between red and blue. In this case even the most basic logic will work just fine.
if (red > blue) {
ball = red
} else {
ball = blue
Worried that it âseesâ red when there is no game piece present? Well, the color sensor V3 includes a proximity sensor. So you can use the proximity sensor to detect whether or not the game piece is there at all. If it is, then simply check if its more red or blue.
I knew that, but had forgotten about it ⌠We were already contemplating a âpresenceâ sensor within the overall cargo handling scheme. Maybe we can skip a designated one because the color sensor gives us presence and color info at the same time. Thanks!
Thatâs what the proximity sensor that is built into the device is for, though if you are trying to get the color of the object from any kind of range (beyond like 3-6 inches) then you should use a camera instead.
However if youâre trying to show this to the driver in the driver station it should display nothing if you donât have any CARGO inside your robot. I think saying its red even though you have nothing is misleading. You could use a conditional in a proximity sensor to determine this as well but at that point there is no difference between red blue or nothing.
