Posted by Joe Johnson. [PICTURE: SAME | NEW | HELP]
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 10/14/2000 3:24 PM MST
I just finished building another square rack on my deck, using only what I know from the rules (I did not build our evaluation rack).
I have some pointers.
Cut a single leg and cut it long (say 23 inches) then put two elbows on each end and measure the inside dimension that you get. I cut two of them 22 inches only to discover that I needed another 3/4 of an inch between the opposing two legs. I suppose that the elbows I used were made by a different source than the ones that Mike Martus used to make our initial sample.
Uses some thought before you glue. I propose making up 2 sub-assemblies of consisting of 2 elbows and a leg. When you glue the second elbow to the leg, dry-fit the two unused legs into the elbows and use them to help you make sure the elbows are ‘in plane’ with eachother. After you have these two sub-assemblies together, then glue the last two legs to one of them. Finally, glue this C to the other sub-assembly.
Pictures to follow soon.
Good luck.
Joe J.
