Notes on Speakers
So, where will failed shots into the speaker end up? Will it be worthwhile to have a mechanism that picks up from the speaker walls?
They’ll end up on the ground. So if you want to be able to pickup missed shots, you’ll need some form of ground intake. This would also potentially improve your auton capabilities as you’d be able to pick up the notes off the ground then as well.
