I have been unsuccessfully trying to install and run the Vision Coprocessing Software on our Jetson TX1 for about 2 1/2 hours now. Every time, I run
./gradlew build
it compiles successfully, but they always result in the following stack trace:
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/ubuntu/Downloads/Java/output/libopencv_java310.so: /home/ubuntu/Downloads/Java/output/libopencv_java310.so: wrong ELF class: ELFCLASS32
at java.lang.ClassLoader$NativeLibrary.load (Native Library)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1941)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1857)
at java.lang.Runtime.loadLibrary0(Runtime.java:870)
at java.lang.System.loadLibrary(System.java:1122)
at Main.main(Main.java:12)
We are running on a AArch64 NVIDIA Jetson TX1 Development Kit. I have (Oracle) Java 8b121 arm64 installed (it refuses to run any Java executable that is arm32) and Gradle 3.3 with Groovy 2.4.7 and Ant 1.9.6 on Linux 3.10.96-tegra aarch64.
It looks like you are using the build system linked here http://wpilib.screenstepslive.com/s/4485/m/24194/l/687863-off-board-vision-processing-in-java. I hadn’t actually ran it on the TX1, but I know that the builds are for 32 bit arm. So either try finding a 32 bit version of Java, or you will need to find a 32 bit OS for the TX1. I’m not familiar enough with it to know where to find either of those.
