NXC Program advice
I was wondering if I could get a little advice regarding this program I’m writing. I’m not too worried about it working or compiling or anything like that, but more if there’s anything I can do to clean it up or anything else along that line. I’ve been learning NXC as part of a robotics class, but I have not actually taken a formal coding class, so while I can code, we’ve never discussed best practices, etc., so I don’t feel like I’m necessarily writing the best code. I’ve posted the code below, and any recommendations would be very much appreciated
//Motors
#define   L_DRIVE         OUT_B
#define   R_DRIVE         OUT_C
#define   B_DRIVE         OUT_BC
#define   ARM             OUT_A
//Sensors
#define   SONIC           SENSOR_1
#define   SONIC_PORT      S1
#define   ARM_TOUCH_PORT  S2
#define   ARM_TOUCH       SENSOR_2
#define   BUMPER          SENSOR_3
#define   BUMPER_PORT     S3
#define   LIGHT           SENSOR_4
#define   LIGHT_PORT      S4
//Variables
#define   CURRENT         y
#define   START           x
#define   ORIENTED        z
//Constants
#define   WALL_DIST       23 //centimeters
//Logging
#define   FILE_NAME       "data.log"
#define   FILE_SIZE       512
//Bluetooth
#define   OUTBOX1          1      //ready
#define   OUTBOX2          2      //arm is hit
#define   INBOX3           3      //partner has ball
#define   INBOX4           4      //partner gave ball
#define   INBOX5           5      //Right turn for orientation
#define   INBOX6           6      //Left turn for orientation
#define   CONNECTION       0
#define   CONNECTION_GOOD  "Connected"
#define   CONNECTION_BAD   "No connection"
mutex motorMutex;
byte handle;
unsigned int result;
const int file_size = FILE_SIZE;
short bytes_written;
string write, arm, drive, turn;
bool has_ball;
//Arm Subroutines//
void deploy_arm() {                             //deploys arm to receive ball
  arm = "deploying arm";
  WriteLnString(handle, arm, bytes_written);    //reports status to log
  OnFwd(ARM, 65);
  Wait(500);
  OnRev(ARM, 30);                               //active braking to reduce impact
  Wait(300);
  OnRev(ARM, 20);
  Wait(200);
  Off(ARM);
  Wait(2000);
  SendRemoteBool(CONNECTION, OUTBOX1, true);    //sends ready signal to partner bot
  arm = "arm deployed";
  WriteLnString(handle, arm, bytes_written);    //logfile
void drop_arm() {                               //drops arm for scoring subrout.
  OnFwd(ARM, 30);                               //includes active braking
  Wait(500);
  OnRev(ARM, 40);
  Wait(300);
  OnRev(ARM, 20);
  Wait(200);
  Off(ARM);
  Wait(2000);
void raise_arm() {                              //raises arm for scoring subrout
  OnRev(ARM, 95);
  Wait(1000);
  Off(ARM);
  Wait(1000);
//Drive Subroutines//
void forward() {
  drive = "moving forward";
  WriteLnString(handle, drive, bytes_written);
  OnFwd(B_DRIVE, 50);
void backward() {
  drive = "moving backward";
  OnRev(B_DRIVE, 50);
void rotate_right() {
  drive = "turning right";
  OnFwd(R_DRIVE, 50);
  OnRev(L_DRIVE, 50);
void rotate_left() {
  drive = "turning left";
  OnFwd(L_DRIVE, 50);
  OnRev(R_DRIVE, 50);
//Bluetooth Subroutines//
void receive_color() {                          //receives data on colored circle from partner bot
  bool left, right;                             //if on red circle, partner sends true on inbox5
  ReceiveRemoteBool(INBOX5, true, left);        //if on blue circle, partner sends true on inbox 6
  ReceiveRemoteBool(INBOX6, true, right);       //sub. sets turn direction according to which side is true
  until((left == true) || (right == true));
  if(right == true) {
    turn = "right";
  else if(left == true) {
    turn = "left";
void receive_ball() {                           //stops execution until arm bumper is pressed by partner bot
  bool clear;                                   //once bumper is pressed, confirmation signal is sent to outbox1
  clear = false;                                //after confirmation, waits for "all clear" signal from partner
  until(ButtonPressed(ARM_TOUCH, true));
  while(clear = false) {
    ReceiveRemoteBool(INBOX4, true, clear);
  clear = false;
//Complex Subroutines//
void orient_hoop() {                            //orients bot towards hoop
  bool ORIENTED;                                //orientation is based off of distance detected on ultrasonic sensor
  string orient;                                //the distance from the hoop wall is shortest, so checks against that distance
  orient = "orienting";
  WriteLnString(handle, orient, bytes_written);
  while(ORIENTED = false) {                           //loops until oriented
    if(SONIC<WALL_DIST) {                       //checks distance off of ultrasonic sensor
      switch(turn) {
        case "right":                           //checks turn direction from receive_color()
          rotate_right();                       //rotates right to orient
          Wait(1000);
          Off(B_DRIVE);
          break;
        case "left":                            //rotates left to orient
          rotate_left();
          Wait(1000);
          Off(B_DRIVE);
          break;
    else if(SONIC>=WALL_DIST) {                 //finds correct wall
      ORIENTED = true;                          //clears while loop
      orient = "oriented";
void score() {                                  //raises and lowers arm using respective subs.
  string score;
  score = "scoring";
  WriteLnString(handle, score, bytes_written);
  raise_arm();
  drop_arm();
void drive_hoop() {                             //drives to the hoop after locating wall
  string hoop;
  hoop = "driving to hoop";
  WriteLnString(handle, hoop, bytes_written);
  forward();
  Wait(2000);
  Off(B_DRIVE);
  hoop = "at hoop";
//Tasks//
task bt_status() {                              //continually monitors bluetooth connection to partner
  string good, bad;
  int connection;
  connection = BluetoothStatus(CONNECTION);
  good = CONNECTION_GOOD;
  bad = CONNECTION_BAD;
  while(true) {
    switch(connection) {
      case 0:
        TextOut(0, LCD_LINE8, good);
        WriteLnString(handle, good, bytes_written);
        break;
      default:
        TextOut(0, LCD_LINE8, bad);
        WriteLnString(handle, bad, bytes_written);
        break;
task main() {
  has_ball = false;
  start bt_status;
  string write;
  result = CreateFile(FILE_NAME, file_size, handle);
  if (result == LDR_FILEEXISTS)
    result = OpenFileAppend(FILE_NAME, file_size, handle);
  if (result == LDR_SUCCESS) {
  else if (result == LDR_FILEISFULL)
    TextOut(0, LCD_LINE1, "file is full");
  else {
    TextOut(0, LCD_LINE1, "open failed");
    TextOut(0, LCD_LINE2, "error");
    NumOut(50, LCD_LINE2, result);
  SetSensorLowspeed(SONIC_PORT);
  SetSensorTouch(BUMPER_PORT);
  SetSensorTouch(ARM_TOUCH_PORT);
  SetSensorLight(LIGHT_PORT);
  write = "sensors done";
  Wait(5000);
  receive_color();
  orient_hoop();
  drive_hoop();
  while(true) {
    deploy_arm();
    receive_ball();
    while(has_ball == false) {
      has_ball = false;
      score();
      ReceiveRemoteBool(INBOX3, true, has_ball);
Also, just for reference, the NXC language is basically C, but with a couple of additional loop statements and APIs that let it play nice with the Lego NXT brick.
