NXT Brick
Hi,
We are a rookie FTC team that has had many different problems. We have problems with our NXT Brick freezing. I have tried redownloading the firmware and switching our NXTs. I have had no success. I am thinking that there is something wrong with my program. I don’t know what is wrong because i haven’t messed with the template more than necessary. Could someone look at my program and see if something changed?
Thanks
Hampton and Geeks in Just Their Underpants
I’d look at the code but none exists!
I’ve worked with the NXT a lot in the past. (For FLL…) I would recommend calling LEGO EDU, they can help you with any problems you might have. If you do post your code, I would love to take a look at it for you.
Hope that helps!!!
You might have better luck posting in the FTC specific forum.
http://www.chiefdelphi.com/forums/forumdisplay.php?f=146
Are you using labview or RobotC? If you’re using labview, and I don’t know for sure if this could be an issue, it’s just a guess, I’ve heard of teams either maxing out, or coming close to maxing out, the NXT’s memory. I wonder if you just have too many programs on the NXT.
Thanks for the help. Here is the code. We are using LabVIEW. I will try to delete some of the programs on the NXT and see if that helps.
FTCTeleopFull new version 3.vi (52.8 KB)
