[OFF] Summer Heat 2019
Draft will be run at 2019-06-29T00:00:00Z and the signup will close on 2019-06-28T14:00:00Z (additionally the team list will be finalized at this time)
This will be run the same fashion as all previous OFF drafts with tiers and timing and all. It will not follow the different rules being used on the Texas Robotics Invitational offseason competition.
Team List
Team # Team Name
58 The Riot Crew
131 CHAOS
133 B.E.R.T.
172 the Northern Force
319 Big Bad Bob
885 Ro-bovines
1058 PVC Pirates
1071 Team MAX
2523 Tech Storm
2648 Infinite loop
3461 Operation peacce
3597 Robo-Rangers
3623 The TerrorBots
4041 Gardiner Iron Tigers
4055 NRG
4311 Swampscott Currents
4473 REM Delta Prime
4564 Orange Chaos
5687 The Outliers
5813 Morpheus
6153 Blue Crew
6224 Saint Dominators
6328 Mechanical Advantage
6329 Bucks Wrath
6337 Terror Bytes
9997 Orange Choas
9998 LongMEMEtal Robotics
9999 Gerbils Wrath
  1. Erik2175
  1. Erik2175
  2. Brian_Maher
  1. Erik2175
  2. Brian_Maher
  3. pchild
  1. Erik2175
  2. Brian_Maher
  3. pchild
  4. Stryker :shark:
  1. Erik2175
  2. Brian_Maher
  3. pchild
  4. Stryker :shark:
  5. ChanOH7x7
  1. Erik2175
  2. Brian_Maher
  3. pchild
  4. Stryker :shark:
  5. ChanOH7x7
  6. Kaitlynmm569
  1. Erik2175
  2. Brian_Maher
  3. pchild
  4. Stryker
  5. ChanOH7x7
  6. Kaitlynmm569
  7. Nate_Johansen
  1. Erik2175
  2. Brian_Maher
  3. pchild
  4. Stryker
  5. ChanOH7x7
  6. Kaitlynmm569
  7. Nate_Johansen
  8. ThatSoftwareGuy
Can I join
Absolutely!
Just add your name to the list. And maybe check out some of the earlier draft threads to see how it works if you haven’t played before.
There’s also a discord for discussing Fantasy FIRST if you’d like to join.
  1. Erik2175
  2. Brian_Maher
  3. pchild
  4. Stryker
  5. ChanOH7x7
  6. Kaitlynmm569
  7. Nate_Johansen
  8. ThatSoftwareGuy
  9. Akod
  1. Erik2175
  2. Brian_Maher
  3. pchild
  4. Stryker
  5. ChanOH7x7
  6. Kaitlynmm569
  7. Nate_Johansen
  8. ThatSoftwareGuy
  9. Akod
  10. CSherm
  1. Erik2175
  2. Brian_Maher
  3. pchild
  4. Stryker
  5. ChanOH7x7
  6. Kaitlynmm569
  7. Nate_Johansen
  8. ThatSoftwareGuy
  9. Akod
  10. CSherm
  11. Hailey.faiella
  1. Erik2175
  2. Brian_Maher
  3. pchild
  4. Stryker
  5. ChanOH7x7
  6. Kaitlynmm569
  7. Nate_Johansen
  8. ThatSoftwareGuy
  9. Akod
  10. CSherm
  11. Hailey.faiella
  12. BrennanB
  1. Erik2175
  2. Brian_Maher
  3. pchild
  4. Stryker
  5. ChanOH7x7
  6. Kaitlynmm569
  7. Nate_Johansen
  8. ThatSoftwareGuy
  9. Akod
  10. CSherm
  11. Hailey.faiella
  12. BrennanB
  13. Attention
  1. Erik2175
  2. Brian_Maher
  3. pchild
  4. Stryker
  5. ChanOH7x7
  6. Kaitlynmm569
  7. Nate_Johansen
  8. ThatSoftwareGuy
  9. Akod
  10. CSherm
  11. Hailey.faiella
  12. BrennanB
  13. Attention
  14. Miklast
  1. Erik2175
  2. Brian_Maher
  3. pchild
  4. Stryker
  5. ChanOH7x7
  6. Kaitlynmm569
  7. Nate_Johansen
  8. ThatSoftwareGuy
  9. Akod
  10. CSherm
  11. Hailey.faiella
  12. BrennanB
  13. Attention
  14. Miklast
  15. abbymarie
  1. Erik2175
  2. Brian_Maher
  3. pchild
  4. Stryker
  5. ChanOH7x7
  6. Kaitlynmm569
  7. Nate_Johansen
  8. ThatSoftwareGuy
  9. Akod
  10. CSherm
  11. Hailey.faiella
  12. BrennanB
  13. Attention
  14. Miklast
  15. abbymarie
  16. Max_Boord
  1. Erik2175
  2. Brian_Maher
  3. pchild
  4. Stryker
  5. ChanOH7x7
  6. Kaitlynmm569
  7. Nate_Johansen
  8. ThatSoftwareGuy
  9. Akod
  10. CSherm
  11. Hailey.faiella
  12. BrennanB
  13. Attention
  14. Miklast
  15. abbymarie
  16. Max_Boord
  17. Darre
  1. Erik2175
  2. Brian_Maher
  3. pchild
  4. Stryker
  5. ChanOH7x7
  6. Kaitlynmm569
  7. Nate_Johansen
  8. ThatSoftwareGuy
  9. Akod
  10. CSherm
  11. Hailey.faiella
  12. BrennanB
  13. Attention
  14. Miklast
  15. abbymarie
  16. Max_Boord
  17. Darre
  18. CurtisB42
