On Board Computer
I have seen some teams mount min itx computer on their robots. I would like to know how you would hook it up and what are some of the uses of one.
We used it for image processing this year. We had a Kinect plugged into the onboard PC (consisting of a Zotac ITX motherboard with a dual-core Atom 330 and an SSD), image data was sent back to an applet running on the driver station where the driver could line up the target, get the distance, and then the wheel speed for the shooter would be calculated. Some teams did great image processing by using the Axis camera and doing all the processing on the driver station, but there certainly are some nice benefits to doing it all on the robot (one of them being that you can use the Kinect on the robot) and we hope to improve our system in the future as well.
Thanks. But how did you power it? Did you use a pc power supple connected to the pd board or something else?
The simplest way to power an onboard PC would be with a DC/DC PicoPSU. It’s much lighter and smaller than a standard PSU.
Here’s one you could use.
It attaches above the motherboard’s 24 pin socket. You would then strip the leads that are meant to go to an AC converter (laptop power brick) and plug those into a 12v on the NI PD Board. Simple as that.
thanks
The Zotac board that we used (http://www.zotacusa.com/zotac-ion-itx-t-series-ionitx-t-u.html) accepted a 19volt input so we just got a 12 to 19 volt power supply, very clean setup. Avoids dealing with the 24 pin atx connector to begin with
Is a board like thisalso a viable idea? Our team was thinking about building an onboard computer, and we wanted to keep things on the cheap. There is a $400 limit after all.
Also, will there be any problems with bootup time? The last thing I want is to turn our robot on, and have the FTA giving our team weird looks every match because windoze is taking it’s sweet time.
You could always just do your image processing on your C-rio? I believe we did that and didn’t have a problem but your just have to have like absolutely as much off load on the cpu on board so that the cpu can actually do it. This resorted to us using 2CAN and integrated PID loops on the Jaguars them selves.
thanks for the suggestion but in I think I would go with a mini itx board to keep space down
about the role of keeping each part under $400 does this mean keeping the combined total of the cpu motherboard ssd and ram under $400 or keeping each part under the limit
Our total was under $400 I recall, just the Zotac board + RAM + SSD should keep you under $400 no problem (and I’m pretty sure it would be counted each party individually anyway but I’m not completely sure).
Bootup time is very fast, under 30 seconds with an SSD, so plenty of time from when the FTAs have you power up the robot to when it’s situated on the field ready to go.
IMHO you definitely want to go for a low-power, compact solution like Atom.
what os are you running? and what’s the tdp of the atom
The pico itx power supply that was linked probably is not a good choice. It is not designed for voltage drops like those that can happen on a robot. The same company makes the m3 model that can take drops down to 6 volts.
Thanks!
one more thing how do you control the program owns you are running?
We ran Ubuntu on ours. I want to say the TDP of the Atom itself is like 13W but I’d have to check, it’s very low.
We had the server side launch on startup so it was running when the robot was powered up.
We used a Pandaboard running Ubuntu. It runs on 5V, 2A so under 10W. We set up a user that auto-logs in on startup and then launched our program in that user’s .profile file. We’re working on a paper that describes everything in detail, hopefully it won’t take too much longer.
Hope to see the paper soon
That’s not necessarily true. Reconsider how you perform your image processing. It’s perfectly reasonable to process a single frame to get all the information you need to lock on to the target and shoot accurately.
Vision processing does not necessarily mean processing vision in real-time, at real-time speeds. That is a mistake many programmers make. In fact, I can tell you that most manufacturing vision systems we have in our production lines use the single-frame method.
Yup. We grabbed one frame, processed it in about 100ms, then fed the result into a control loop using the gyro. We were even able to pull out our lateral position on the field to shoot off center if we were on the side of the key, allowing us to have an accurate alliance bridge autonomous mode. We did this spending 0 dollars and 0 hours on an external computer.
