Onebox not working
frc-docs is in the process of adding Open Graph support. When I tried the test site (link below), it did not generate a Onebox. Is there a setting to only enable Oneboxes on certain sites? It does work on other sites that support Open Graph.
https://frc-docs--711.org.readthedocs.build/en/711/docs/getting-started/getting-started-frc-control-system/intro.html
It has description set, which per below is the the only thing needed for Onebox to work.
Looking at this: https://github.com/discourse/onebox/tree/master,
it appears that domains have to be whitelisted.
I think it needs to be added to whitelisted_generic_onebox.rb: https://github.com/discourse/onebox/blob/master/lib/onebox/engine/whitelisted_generic_onebox.rb.
It would suggest adding
  • docs.wpilib.org
  • frcdocs.wpi.edu
  • frc-docs.readthedocs.io
I’ve added these 3 … let me know if it works or needs updating.
Could you try adding wpilib.org?
And, could you add a second copy with https:// prepended? -> https://wpilib.org
Also,
I found discourse specific info: Quickly explain what Onebox is? - feature - Discourse Meta
edit:
Does it need https:// for all of the previous three urls too?
curl on http://docs.wpilib.org/en/latest/ is rejected but works on https://docs.wpilib.org/en/latest/.
Looking through the source code in the above posted github link, they seem to handle urls that need to change http to https differently
I added them in with https also, no dice. Not sure, without digging in further, why it’s not showing. Found some more discussion about it not working on every site, here:
I just got openbox with wpilib docs working on a local Discourse instance. Now I just have to figure out why and how.
Ok. I think I’ve cracked it.
First, testing woes:
Discourse caches onebox requests for 24 hours so trying the same url doesn’t work. So to test, urls have to be appended with garbage/unique query strings. (https://url.html?q=anger, https://url.html?q=entireminuteswasted, …)
The frc docs issue:
If the requested page contains a <link rel="canonical" ...>, then Onebox uses that and ignores the actual url that was passed in. The frc docs canonical points to the stable version of the docs; The opengraph data only exists in the latest version. So, onebox never sees the opengraph data.
Fixes
Fix 1
Once the opengraph version of frc docs makes its way from latest to stable, it should work.
Fix 2
Onebox ran into this same issue with instagram.
So, they have an override for this.
In the onebox gem’s lib/onebox/helpers.rb, IGNORE_CANONICAL_DOMAINS (line 8 ish) should change from:
 IGNORE_CANONICAL_DOMAINS ||= ['www.instagram.com']
to:
 IGNORE_CANONICAL_DOMAINS ||= ['www.instagram.com', 'wpilib.org']
I’d like to avoid editing any of the core code (or libraries).
If you wanted to write a Discourse plugin to modify this behavior I would consider installing. (Or submit a pull request to onebox on github to add wpilib.org to their code)
I had started to work on the plugin but onebox looks for an undocumented html property that ignores the canonical url.
