Hello,
We are currently using a raspberry pi 3 for our vision. We’ve coded up an app using opencv (not using grip) app that grabs a frame from the camera and forwards the output to our driver station. We had to code our app to send jpeg image (160x120 image @ 5 FPS) with jpeg quality at 60. The jpeg is transmitted to the driver station via UDP where it is displayed via another opencv app. I would to push the a faster frame rate, but due to the radio link that was the best we could do. It did allow for nearly real-time view of the field from the bot.
I was wondering sizes and frame rates are rest of you using?
I am wondering if we might be doing something inefficient in our code if the rest of you are able to do better FPS with larger images.
Thanks,
K Murphy
