Is there an available method in the API that is the opposite operation of fromFieldRelativeSpeeds?
i.e. if I have a ChassisSpeed, how to convert that to field-relative X and Y speeds?
Doesn’t ChassisSpeed already contain field-relative x and y speeds?
vxMetersPerSecond and vyMetersPerSecond
Apply trig to your chassis speeds using your gyroscope.
public ChassisSpeeds getFieldRelativeSpeed(double robotX, double robotY, double omegaRadiansPerSecond, Rotation2d robotAngle) {
// Gets the field relative X and Y components of the robot's speed in the X axis
double robotXXComp = robotAngle.getCos() * robotX;
double robotXYComp = robotAngle.getSin() * robotX;
// Gets the field relative X and Y components of the robot's speed in the Y axis
double robotYXComp = robotAngle.getSin() * robotY;
double robotYYComp = robotAngle.getCos() * robotY;
// Adds the field relative X and Y components of the robot's X and Y speeds to get the overall field relative X and Y speeds
double fieldX = robotXXComp + robotYXComp;
double fieldY = robotXYComp + robotYYComp;
return new ChassisSpeeds(fieldX, fieldY, omegaRadiansPerSecond);
I know im misusing ChassisSpeeds
by using them to store a field relative speed (that’s not its intention). 1622 has their own FieldRelativeSpeed
class which is what this method is in, you pass in a ChassisSpeeds
and a gyro angle and it convert it to a FieldRelativeSpeed
. For the sake of simplicity I didn’t bother including that here and just modified the method to just use ChassisSpeeds
fromFieldRelativeSpeeds rotates your velocity vector by your gyro angle to get to robot-centric. To go the opposite way you can call the same method with the negative of your gyro angle.
As in gyro angle * -1?
Or some fancy mod math?
