I’m going to try to answer your questions as best I can.
If you’re talking about the Dashboard port for connecting to a computer to read out, or the radio port, it is a standard 9 pin serial port. The name for these connectors is a DB-9.
The robot controller is given to teams by FIRST, so I assume you mean the code storage size. There is a limit, but on the current controllers, unless your code is very complex it shouldn’t be a problem.
I think the English translation on this one is a little broken, but I think you’re asking if you can make an adapter to plug into the ports on the OI. You can plug in standard toggle switches and the like, but you cannot use anything that requires its own battery, except the USB-CHICKLET, which you can order from IFI.
DB-15 connectors have 15 pins. There are 5 of them on the OI, 4 for joysticks, and one for the competition port. They are the same as the ‘game’ or ‘joystick’ port on an older computer.
Absolutely. You can use any joystick, steering wheel, or any other device you can plug into the OI, as long as it doesn’t need its own battery.
I think in question 3 you are asking if you can make an adapter for your operator interface. For your driver in the joy stick port. Though I do not know the answer I hope that that clarifies it for someone else who does.
Ok, you posted a new post while I was typing my last post. In responce you will need to go to IFI Robotics’ site and buy a thing called a chicklet. This will alllow you to convert from USB to gameport.
<R101> The OPERATOR CONSOLE designed by the team must fit on the 60” wide by 12” deep
shelf in the Alliance Station (excluding any items that are held or worn by the DRIVERS
during the MATCH).
Nothing says you can’t take the USB port off and wire the sensors inside whatever you want to use to the appropriate connector yourself. (Other than time…)
