Hey! In our teleop period i have some code for our Auto Balance thats supposed to run when I press Joystick Button 7, and the code does work once I press the button. The problem is is when I press the button again to turn off the code it continues to run, even if I disable the robot. The only way to go back to regular joystick-controlled robot is if i re-deploy the code. Any ideas why this is? Thanks.
// Copyright (c) FIRST and other WPILib contributors.
// Open Source Software; you can modify and/or share it under the terms of
// the WPILib BSD license file in the root directory of this project.
package frc.robot;
//import frc.robot.commands.ToggleBalance;
import com.kauailabs.navx.frc.AHRS;
//import edu.wpi.first.wpilibj.DriverStation;
import edu.wpi.first.wpilibj.drive.MecanumDrive;
import edu.wpi.first.wpilibj.motorcontrol.PWMSparkMax;
//import edu.wpi.first.wpilibj2.command.button.JoystickButton;
import edu.wpi.first.wpilibj.I2C;
//import edu.wpi.first.wpilibj2.command.Command;
import edu.wpi.first.wpilibj.Timer;
private static final int kJoystickChannel = 0;
private static MecanumDrive m_robotDrive;
private static Joystick m_stick;
AHRS ahrs;
boolean autoBalanceXMode;
boolean autoBalanceYMode;
boolean isBalanceEnabled = false;
static final double kOffBalanceAngleThresholdDegrees = 10;
static final double kOonBalanceAngleThresholdDegrees = 5;
//Joystick Vars
//private JoystickButton m_toggleBalance;
@Override
public void robotInit() {
PWMSparkMax frontLeft = new PWMSparkMax(Constants.kFrontLeftChannel);
PWMSparkMax rearLeft = new PWMSparkMax(Constants.kRearLeftChannel);
PWMSparkMax frontRight = new PWMSparkMax(Constants.kFrontRightChannel);
PWMSparkMax rearRight = new PWMSparkMax(Constants.kRearRightChannel);
// Invert the right side motors.
// You may need to change or remove this to match your robot.
frontRight.setInverted(true);
rearRight.setInverted(true);
m_robotDrive = new MecanumDrive(frontLeft, rearLeft, frontRight, rearRight);
m_stick = new Joystick(kJoystickChannel);
//m_toggleBalance = new JoystickButton(m_stick, Constants.toggleBalance);
ahrs = new AHRS(I2C.Port.kMXP); /* Alternatives: SPI.Port.kMXP, I2C.Port.kMXP or SerialPort.Port.kUSB */
@Override
// Use the joystick X axis for lateral movement, Y axis for forward
// movement, and Z axis for rotation.
m_robotDrive.driveCartesian(-m_stick.getY(), m_stick.getX(), m_stick.getZ());
//if doesnt work, add gyroAnlge arg = 1.0
if(m_stick.getRawButtonPressed(7)) {
isBalanceEnabled = true;
if(m_stick.getRawButtonPressed(8)) {
if(isBalanceEnabled){
while(isTeleop() && isEnabled() && isBalanceEnabled) {
double xAxisRate = m_stick.getX();
double yAxisRate = m_stick.getY();
double pitchAngleDegrees = ahrs.getPitch();
double rollAngleDegrees = ahrs.getRoll();
isBalanceEnabled = !isBalanceEnabled;
if ( !autoBalanceXMode &&
(Math.abs(pitchAngleDegrees) >=
Math.abs(kOffBalanceAngleThresholdDegrees))) {
autoBalanceXMode = true;
else if ( autoBalanceXMode &&
(Math.abs(pitchAngleDegrees) <=
Math.abs(kOonBalanceAngleThresholdDegrees))) {
autoBalanceXMode = false;
if ( !autoBalanceYMode &&
autoBalanceYMode = true;
else if ( autoBalanceYMode &&
autoBalanceYMode = false;
// Control drive system automatically,
// driving in reverse direction of pitch/roll angle,
// with a magnitude based upon the angle
if (autoBalanceXMode) {
double pitchAngleRadians = pitchAngleDegrees * (Math.PI / 180.0);
xAxisRate = Math.sin(pitchAngleRadians) * -1;
System.out.println(pitchAngleDegrees);
if (autoBalanceYMode) {
double rollAngleRadians = rollAngleDegrees * (Math.PI / 180.0);
yAxisRate = Math.sin(rollAngleRadians) * -1;
System.out.println(rollAngleDegrees);
m_robotDrive.driveCartesian(xAxisRate, yAxisRate, m_stick.getTwist());
Timer.delay(0.005); // wait for a motor update time
