Our Computer won't connect to the roboRio
Pretty self explanatory. We can’t connect with a wire because we’re testing something autonomous. This is the first time we’ve had this problem, but normally we do use a different computer, but we have to use this one for a while instead. What’s the issue and how can we fix it?
Usually you’ll need to provide more info to help diagnose issues like this.
Your computer is connecting to the radio over wifi, but the driver station doesn’t see the roborio? Code is already deployed to the robot, or are you trying to do that as well?
For starters you can try turning off the Windows Firewall, for all networks.
Which of the troubleshooting steps have you tried, and which of them did or did not work?
