OUR ROBOT WON'T DRIVE!!
We got this conflict message while trying to upload our program to the RoboRio. Does anyone know what this means? Thank you:D
Access denied: This target is running a version of LabVIEW that is different than LabVIEW on the host computer. For Real-Time targets, you can verify the version and reinstall the Real-Time software using MAX.
Have you flashed the RoboRio with the current Labview? or is the one on your computer out of date.
Pro Tip: Java
How do I figure out which one is out of date, and how do I update it?
You should just be able to see when you start LabVIEW. I think it shows the version. Here’s the Screensteps guide on installing the update suite. You should just be able to follow that guide for it and update both the Driver Station and your copy of labVIEW
