Hey! I was wondering if anyone knew what kind of sensor is in the Outer Works Sensors. For example, if a robot held open the Sally Port, can two robots go thru, one immediately after each other, making that defense have zero strength? Or would the Sally Port door have to close for it to work?
Basically, how are robots going thru defenses counted? Our thoughts were that that’s a lot of counting and details for match personnel to input into FMS.
First of all, it is a person that watches the robots and manually sets the defense health. I am pretty sure that your sally door example would be legal because there is nothing against it in the rules (that I can find).
If you think that’s a lot of details for match personnel to input into FMS, you evidently aren’t familiar with the 2014 scoring methodology…
Trust me, I rather suspect that the defenses, which are based on somewhat of a judgement call, will be manually input. The interface actually wouldn’t even be that hard, just need a picture of each defense. Even easier than last year!
Also, I suggest noting that no definition of Crossing a Defense makes any reference to exactly what state the Defense may be in at any point during the crossing (other than, on the field).
There are ref touch pads surrounding the field just like last year in the just released photos. Those photos are also fantastic. I thought the vision from the behind the glass area would be a lot more obstructed than it appears in the photos (that drawbridge is the only one that is really bad, Sally Port not so much), Portcullis not so bad at all. The rest of them are low.
I believe the door (in this case) can be held open by one robot and the defense weakened with passage by another alliance member. However, the door must be reset (the door must close) and then reopened before another robot can weaken it further.
That’s it. Nothing about the sally port closing, the portcullis lowering, the drawbridge returning to vertical, the cheval de frise returning to position, the flap on the low bar being stationary.
Gosh, I was pretty positive we discussed the defense “resetting” in a strategy meeting. But then again I’ve been spending most of my time building field elements.::ouch::
