I’ve been tossing around an idea for a while to mount drive gearboxes to the outside of a versaframe rail. Sort of a “doubly flipped” arrangement. I’ve never designed a FIRST gearbox before, but I figured I’d give it a shot and see if I could come up with something worth prototyping in the fall.
Attached is what I came up with. It’s not perfect, but it’s got some interesting aspects:
- Uses 4 775 pro motors, capped at 10V (and perhaps some other fancy current limiting), following the pioneering experience of Teams 2451 and 88
- Mounting to the outside of a “West Coast” style frame means it is just as easy to remove the gearbox for maintenance as it is to remove a wheel. It also gives freedom to move the gearbox away from the center of the robot if that space is needed.
- Uses steel gears and hardware from Andymark’s EVO shifter (except for two gear sizes which sadly I could only find in aluminum from VEX)
- Currently geared 16.5x in high gear, 38.5x in low gear (2.3x spread), but these can be adjusted by changing the second and third stage ratios.
- To fit in the wheel well, the gearbox can’t be any more than 3" thick. To save space, I put the first stage gear above the dog. Unfortunately this means we need extra long pinions for the 775 pros
- Uses a Celt-X hex-bore encoder (3D printed modification of a CTRE versa planetary encoder)
There’s an incomplete CAD model here: https://drive.google.com/file/d/0B16qRDFhn0uuZF9VeURvQkRqOUE/view?usp=sharing I would love to hear any comments, suggestions or insights from people with more experience designing these.
