Hello,
We are trying to write robot code on our laptop, and VSCode is saying that @Override and the Robot class cannot be resolved to a type. We did not change anything, and we cannot figure out what is wrong. Help is appreciated!!
Hello,
Usually indicates you didn’t import something.
We have all the necessary imports and the issue still persists.
Could you link to your code
package frc.robot;
import com.ctre.phoenix.motorcontrol.NeutralMode;
import com.ctre.phoenix.motorcontrol.can.WPI_TalonFX;
import com.revrobotics.CANSparkMax;
import com.revrobotics.CANSparkMax.IdleMode;
import com.revrobotics.CANSparkMaxLowLevel.MotorType;
import edu.wpi.first.wpilibj.DriverStation;
import edu.wpi.first.wpilibj.SpeedControllerGroup;
import edu.wpi.first.wpilibj.drive.MecanumDrive;
static String gameData;
// Creating the drive motors.
CANSparkMax frontLeftMotor, frontRightMotor, backLeftMotor, backRightMotor;
WPI_TalonFX fLShooter, bLshooter, frshooter, brshooter;
CANSparkMax rworm, lworm;
WPI_TalonFX intake;
// Creating the Mecanum Drive.
MecanumDrive mecanumDrive;
// Creating the PS4 controller.
Joystick PS4;
SpeedControllerGroup wormDrive;
double PS4_L_Y;
final double PS4_TRIGGER_DEADBAND_POSITIVE = 0.2;
final double PS4_TRIGGER_DEADBAND_NEGATIVE = -0.2;
@Override
public void robotInit() {
// Dummy IDs for right now!
// frontLeftMotor = new (1);
// frontRightMotor = new WPI_TalonFX(3);
// backLeftMotor = new WPI_TalonFX(2);
// backRightMotor = new WPI_TalonFX(4);
frontLeftMotor = new CANSparkMax(1, MotorType.kBrushless);
frontRightMotor = new CANSparkMax(2, MotorType.kBrushless);
backLeftMotor = new CANSparkMax(3, MotorType.kBrushless);
backRightMotor = new CANSparkMax(4, MotorType.kBrushless);
fLShooter = new WPI_TalonFX(5);
bLshooter = new WPI_TalonFX(7);
frshooter = new WPI_TalonFX(6);
brshooter = new WPI_TalonFX(8);
rworm = new CANSparkMax(9, MotorType.kBrushless);
lworm = new CANSparkMax(10, MotorType.kBrushless);
intake = new WPI_TalonFX(11);
// Adding the drive motors to the Mecanum Drive.
mecanumDrive = new MecanumDrive(frontLeftMotor, backLeftMotor, frontRightMotor, backRightMotor);
// Assigning the PS4 controller the ID of 0.
PS4 = new Joystick(0);
fLShooter.setNeutralMode(NeutralMode.Brake);
bLshooter.setNeutralMode(NeutralMode.Brake);
frshooter.setNeutralMode(NeutralMode.Brake);
brshooter.setNeutralMode(NeutralMode.Brake);
rworm.setIdleMode(IdleMode.kBrake);
lworm.setIdleMode(IdleMode.kBrake);
rworm.setInverted(true);
wormDrive = new SpeedControllerGroup(rworm, lworm);
mecanumDrive.setSafetyEnabled(false);
// mecanumDrive.setDeadband(0.3);
@Override
public void robotPeriodic() {
@Override
@Override
@Override
PS4_L_Y = PS4.getY();
if (PS4.getRawButton(9) == true) {
fLShooter.set(1.0);
frshooter.set(-1.0);
} else {
fLShooter.set(0);
frshooter.set(0);
if (PS4.getRawButton(1) == true) {
// fLShooter.set(0.3);
// frshooter.set(-0.3);
// brshooter.set(-0.3);
// bLshooter.set(0.3);
// wormDrive.set(0.3);
wormDrive.set(0.30);
} else if (PS4.getRawButton(2) == true) {
// wormDrive.set(-0.3);
wormDrive.set(-0.30);
} else {
// fLShooter.set(0.0);
// frshooter.set(0.0);
// brshooter.set(0.0);
// bLshooter.set(0.0);
wormDrive.set(0.0);
if (PS4.getRawButton(3) == true) {
intake.set(-0.3);
} else {
intake.set(0);
if (PS4.getRawButton(5) == true) {
bLshooter.set(0.1);
brshooter.set(-0.1);
} else {
bLshooter.set(0.0);
brshooter.set(0.0);
if (PS4_L_Y < 0.2 || PS4_L_Y > -0.2) {
PS4_L_Y = 0;
// Long if statement that acts as a deadband for the drive.
if (((PS4.getX() > PS4_TRIGGER_DEADBAND_POSITIVE) || (PS4.getY() > PS4_TRIGGER_DEADBAND_POSITIVE)
|| (PS4.getZ() > PS4_TRIGGER_DEADBAND_POSITIVE))
|| ((PS4.getX() < PS4_TRIGGER_DEADBAND_NEGATIVE) || (PS4.getY() < PS4_TRIGGER_DEADBAND_NEGATIVE)
|| (PS4.getZ() < PS4_TRIGGER_DEADBAND_NEGATIVE))) {
// mecanumDrive.driveCartesian(-PS4_L_Y, PS4.getZ(), PS4.getX());
mecanumDrive.driveCartesian(PS4.getY(), PS4.getZ(), PS4.getX());
// mecanumDrive.drivePolar(magnitude, angle, zRotation);
} else {
mecanumDrive.driveCartesian(0, 0, 0);
// TODO polar stuff.
// IDK which one we should use; not much documentation on each.
// mecanumDrive.driveCartesian(ySpeed, xSpeed, zRotation, gyroAngle);
@Override
public void testPeriodic() {
Is the build failing, or do you just have errors showing up in the editor in VSCode?
The code builds, but there are errors showing up in VS
Then it’s definitely a vscode/intellisense issue. That’s been reported a number of times on here, with a wide variety of possible solutions that may or may not have actually helped.
Tonight I reinstalled VSCode and the National Instruments stuff and that fixed it…
I’ve found that sometimes opening the file that it has a problem with will make intelliSense go ‘oh wait…’
