I was wondering if anyone here has used Overrunning Clutches on their robot mechanisms? I’ve seen very limited discission over them on CD so there may be a good reason for that. My inital thoughts were installing one on the drive of a flywheel, but I’m wondering if others have any ideas and associated pros and cons. They might be a fairly complex mechanism to design and definitely not, off-the-shelf, but that doesnt mean they couldn’t be in the future for smaller FRC applications. Any thoughts would be appreciated.
Here’s a link to a video explaining them, from the experts at SSS Clutch.
I believe so because rotating the driven input in reverse would disengage the driven end. Since its a ratchet and pall mechanism, I dont think its possible for bi-directional. Maybe this exists for higher loading applications which is where I’ve seen it in O&G.
There are several different and interesting designs of “one way clutches” or “mechanical diodes” as some refer tot hem. Sprag is one. 1-Way roller bearings is another very similar, but slightly different. The Sprag and “roller bearing” style often work off of directional wedge of the rolling elements. Ratchet and pawl is another type.
This design is pretty neat as it effectively is engaging a small section of a spline type section which should lead to a very high capacity potential. Pretty clever.
Ratchet and Pawl get used a fair amount in FRC. Especially for climbers. Many of the rope climbers in 2017 quite literally used a ratchet wrench connected to the 1/2" hex shaft as a way to make an “anti-back drive” mechanism. 2337 used ratchet and pawl on the “shoulder” joint of a large arm in 2011. It wasn’t to permanently hold the arm in one place, but instead was engaged to friction element when the arm would move in the downward direction. This kept the arm from crashing down when being lowered, but didn’t add friction when the arm was being raised. It was a clever idea, though most teams would instead utilize some sort of bungee/spring/gas shock arrangement to do a one directional drive enhancement.
Iirc 254 used a one way bearing in a functionally equivalent way to allow their shooter and climber to share motors. Not sure if it was 2017 or a later year.
