Where should this be located?
Here you go:
<R58> ROBOTS shall use the diagnostic Robot Signal Light provided in the Kit Of Parts. It must be
mounted on the ROBOT such that it is easily visible while standing three feet in front of the
ROBOT in the STARTING CONFIGURATION. The Robot Signal Light must be connected
to the “RSL” supply terminals on the Digital Sidecar, which provides power and control for
the light. The team has no direct control over the light and no programming is required.
Team,
Please make sure the light is securely mounted and inside the robot frame where it will not be torn off during competition. You can find wiring information of the Robot Wiring Diagram on the First Website.
ALSO make sure that it is on the FRONT. Otherwise you show up on the field with a robot facing the wall. And this year you’d really be out of luck with the trailers.
FRONT
