paper: 1103 Scouting database
Thread created automatically to discuss a document in CD-Media.
by: EHaskins
An Access Database that takes the match info, team information, and will generate a report with the teams in each match, their alliance, and all the info you entered.
This is an Access Database that takes the match info, team information, and will generate a report with the teams in each match, their alliance, and all the info you entered.
The database I attached has the team info from Wisconsin, and the match info from today’s practice matches.
You use the teams form to enter information about each team.
You use the Matches form to enter the time/data of each competition and match number.
You then you the AllianceInfo form to enter the alliance groupings. Team#, Alliance must be R or B. Each team has its own record. With the Team#, alliance, and match#. For each match you will have SIX entries in AllianceInfo.
Once you have the info entered you can run the matches report.
Good luck everybody,
FIRST Scouting.zip (52.7 KB)
