paper: 2005/2006 Operator Interface Pinout Guide
Thread created automatically to discuss a document in CD-Media.
by: Ryan Foley
This is an old white paper originally posted by Doogan that I edited for the new IFI system. It is a list of all OI ports, pins, and what each one does (for the default code), and the variable alias for each. It also has 2 other sheets that list the RC outputs and inputs. Everything has an open c…
This is an old white paper originally posted by Doogan that I edited for the new IFI system. It is a list of all OI ports, pins, and what each one does (for the default code), and the variable alias for each. It also has 2 other sheets that list the RC outputs and inputs. Everything has an open column so you can label each pin/ output by what you use it for (arm motor, right front wheel encoder, etc). Enjoy.
Original white paper (2003 systems and older): http://www.chiefdelphi.com/forums/papers.php?s=&action=single&paperid=32
1137973402general_pinout_sheet_for_2005_2006_system.xls (29 KB)
