You can find Harbor Freight 20% off coupons online, and it’s usually only $500 there, so it ends up being $400 for a 7x12. The Seig style chinese lathes are all made in the same place, so you still get the same thing as if you bought from Grizzly, with minor customizations. mini-lathe.com is a good resource.
The 7x10 is actually only a 7x8 (7" diameter part, 8" max length to be simple) and the 7x12 is an actual 7x12, so it’s a good deal to invest in the latter IMO.
Craigslist can sometime have good deals, but you should know what you’re looking for to do that. Measuring the accuracy is critical.
EDIT: In general I would use a mill because of the versatility for FRC, so if it comes down to buying a tool a mill would be my first choice.
Thanks for the heads up, I tired a new system for putting the pictures up from google photos but apparently it doesn’t actually make them public. Should be fixed now.
I’d love to see someone (VexPro?!) sell one of these… it’d be really great to not need to make a part year-after-year just because it’s not sold when it’d be so widely useful.
GREAT improvements! Thanks for the excellent documentation.
As far as epoxy vs RTV silicone:
We were going to use RTV at first, but after a short debate we chose a potting epoxy that my professional colleagues use. The internal magnet(s?) within the Allegro package are quite strong, and when the steel gear is nearby there is a significant attractive force between them. It’s probably a dynamic force as the gear rotates. Had we suspended the sensor in a flexible potting compound like RTV, we were worried about the effects of the induced vibration.
Sorry I haven’t had a chance to read the blog, but that would be a great point to mention in the blog. Many teams probably aren’t familiar with the differences in those compounds and if that is an issue, it would be good for them to see it coming and avoid it.
This is great. I’m adding it to our projects to try in the off-season. We use VersaPlanetary gearboxes everywhere that we can for their small form factor, ease of use and ability to modify gear ratios as-needed. Integrating sensor feedback into that package would be absolutely huge for a team like ours.
