Sorry, blew the original thread away by mis-clicking. I didn’t think regular users had the power to do that, so I was only paying half attention.
I was able to recover the original posts from cache and I’ve recreated them here.
**07-16-2011 08:07 PM
iblis432](http://www.chiefdelphi.com/forums/member.php?u=31791) **
if it only has 1 ethernet port, what does this mean for teams who utilize the camera?
** 07-16-2011 09:38 PM
stevend1994](http://www.chiefdelphi.com/forums/member.php?u=39061)
Originally Posted by **iblis432**
*if it only has 1 ethernet port, what does this mean for teams who utilize the camera?*
IIRC you can run a camera directly through the wireless bridge.
PAR_WIG1350](http://www.chiefdelphi.com/forums/member.php?u=35416)
I would imagine one would access the camera through the D-Link’s switch (it’s just another device on the same network).
** 07-16-2011 09:49 PM
Tristan Lall](http://www.chiefdelphi.com/forums/member.php?u=379)
There’s a good chance the radio supplied in the 2012 kit will be some sort of router with a switch built in. (Has the model been confirmed by FIRST or the controls developers?)
Looks like the new cRIO is an improvement all around, except (arguably) for one little thing. The new, much more convenient power specification means that someone is going to hook it up to 12 V unregulated, and then have it die on them during a match as their battery drains. (Expect this to be verified at inspection, but some cases always slip by.)
One solution might be a tiny little notice on the front of the cRIO with an arrow in the general direction of the power connector (they’re already doing custom silkscreening for the FIRST logo, or a label): “Unless otherwise allowed by FRC rules, connect to 24 V regulated DC power at 4-pin connector on power distribution board (A003206).”
Similarly, the front of the power distribution board also has custom silkscreening. It wouldn’t hurt to put arrows to the headers indicating “Robot Radio”, “Robot Controller” and “Auxiliary (see FRC rules)” for the camera power. This is a constant issue at inspection, and would benefit a lot from some simple error-proofing.
** 07-16-2011 11:02 PM
apalrd](http://www.chiefdelphi.com/forums/member.php?u=32230)
Wow. Those 0.63 pounds are really the best feature of the new cRio.
** 07-16-2011 11:55 PM
AdamHeard](http://www.chiefdelphi.com/forums/member.php?u=7978)
I hope they choose digital sidecar for the fourth channel… otherwise teams will be pretty unhappy when they try to use more than 10 unique motors.
** 07-17-2011 01:11 AM
Tristan Lall](http://www.chiefdelphi.com/forums/member.php?u=379) ](http://www.chiefdelphi.com/forums/member.php?u=379) **
Originally Posted by **AdamHeard**
*I hope they choose digital sidecar for the fourth channel.... otherwise teams will be pretty unhappy when they try to use more than 10 unique motors.*
I hope they can find a way to let teams select the desired modules (and order) when re-imaging it. (Even better would be to get it to detect and recognize modules on the fly, but that might be asking a bit much of the FPGA.)
** 07-17-2011 01:38 AM
AdamHeard](http://www.chiefdelphi.com/forums/member.php?u=7978) ](http://www.chiefdelphi.com/forums/../media/photos/36877?) **
Originally Posted by **Tristan Lall**
*I hope they can find a way to let teams select the desired modules (and order) when re-imaging it. (Even better would be to get it to detect and recognize modules on the fly, but that might be asking a bit much of the FPGA.)*
Correct, that would be a better plan.
** 07-17-2011 08:18 AM
jtdowney](http://www.chiefdelphi.com/forums/member.php?u=15970) ](http://www.chiefdelphi.com/forums/../media/photos/36652?) **
*There's a good chance the radio supplied in the 2012 kit will be some sort of router with a switch built in. (Has the model been confirmed by FIRST or the controls developers?).*
This year we had a switch combined with a bridge/AP, which was a good mix of device (AP for practice, bridge for field). There is no real need for router functionality.
However I am hoping we don’t see too much more of the current D-Link device given all the trouble this year, the long time to update in the WPA line, and ultimately longer times to connect to the field. I’ve heard rumors of FRC wanting to get the rights to the 2009 Linksys gaming adapters in order to arrange a FRC specific product.
Given the cRIO 2 has only one ethernet port, and the arrival of other ethernet devices like the 2CAN, it is clear we will probably continue to use a switch of some sort on board.
** 07-17-2011 09:15 AM
Gdeaver](http://www.chiefdelphi.com/forums/member.php?u=7152)
A USB Host port would have been nice. Some of the things we are playing with for next year would be easier with USB support.
** 07-17-2011 11:41 AM
Jared341](http://www.chiefdelphi.com/forums/member.php?u=2410)
Operation down to 9V is actually a huge feature of the cRIO2, IMO. Various teams ran into cRIO resets caused by momentary low supply voltages at some point or another in 2011 due to a combination of heavy current draw and, in some cases, RS775 motor case shorts. Operating all the way down to 9V will help a great deal in these cases.
** 07-18-2011 11:37 AM
Tom Line](http://www.chiefdelphi.com/forums/member.php?u=18668) **
The loss of the no-app dip switch is troublesome. FRC Labview has well documented issues downloading files when the Crio is already running something. It’s common to have to try several times to get it download correctly (lost connection etc).
A common fix to this was to flip the No-App dip switch so you could boot without the crio running the files.
Having to open the imaging tool to access virtual dip switches while having connectivity problems with the Crio is not a good solution at all.
I have a hate/hate relationship with the tiny recessed reset switches, so trying to add the no-app boot solution to the reset button on the Crio is a bit of a non-starter as well: recessed reset buttons like that get destroyed very quickly by over-zealous folks with sharp things.
** 07-18-2011 01:00 PM
Originally Posted by **Tom Line**
*The loss of the no-app dip switch is troublesome. FRC Labview has well documented issues downloading files when the Crio is already running something. It's common to have to try several times to get it download correctly (lost connection etc).
I have a hate/hate relationship with the tiny recessed reset switches, so trying to add the no-app boot solution to the reset button on the Crio is a bit of a non-starter as well: recessed reset buttons like that get destroyed very quickly by over-zealous folks with sharp things.*
I would be happy if they just fixed the root cause of the problem instead of working around it with the no-app switch, something they should have done back when the problem was first found.
** 07-19-2011 02:41 PM
purpleandplasma](http://www.chiefdelphi.com/forums/member.php?u=47656) **
Do you know when we can buy the cRIO II, and if there is a limit to how many you can buy?
** 07-19-2011 03:11 PM
Mark McLeod](http://www.chiefdelphi.com/forums/member.php?u=4205)
This upcoming 2012 season, as a special introductory offer, teams will be able to purchase (either/or/both)
- (1) cRIO FRC II chassis for ~$300
- (1) cRIO FRC II chassis with 3 modules for ~$550
I speculate that it’s possible NI will allow additional purchases over and above at a more expensive educational price, but no one has said anything about that or what that increased price might be.
No definitive date has been announced for the FRC II release, just “this winter.”](http://www.usfirst.org/roboticsprograms/frc/content.aspx?id=19775) (originally was “this Fall”](http://www.usfirst.org/roboticsprograms/frc/content.aspx?id=19719), but Bill probably thought it through…)
Bill’s Blog has also said they are still working on developing the 2012 control system and plans for Fall Beta Test teams to try it out.
We need more than simply the purchase of the cRIO FRC II hardware.
We will need a workable FRC image and the updated cRIO Imaging Tool that handles it before it’s of much use to us.
I imagine that the hardware, tools and image will first have a limited release to the Beta Teams, before a general release to the rest of the FRC public.
Imaginary Timeline:
- Beta Team applications
- Beta Team selection
- Distribution of beta hardware/software
- Period of Beta testing errors/results/rework and retesting.
- Release to the general public
At a guess I wouldn’t depend on the average team being able to use a new cRIO FRC II any earlier than December…
** 07-20-2011 10:12 AM
Mark McLeod](http://www.chiefdelphi.com/forums/member.php?u=4205) **
How about a chart like this one to demonstrate the network connections to the new (and old) cRIO?
** 09-04-2011 11:04 AM
rjbarra](http://www.chiefdelphi.com/forums/member.php?u=13314)
It looks like the Camera is going to be on the same TCP/IP network. Maybe this years game we will have the opportunity to use a live Video feed.
** 09-04-2011 12:08 PM**
[FONT=Verdana]jtdowney**](http://www.chiefdelphi.com/forums/member.php?u=15970)[/FONT] **
With the D-Link bridge/switch you were able to have the camera on the 10.0.0.0/8 subnet this past year.
** 09-19-2011 01:03 PM
FrankJ](http://www.chiefdelphi.com/forums/member.php?u=46958) ](http://www.chiefdelphi.com/forums/member.php?u=46958) **
Go here to for directions on how to configure the camera to run on the same subnet as your robot. This will allow you to plug the camera into the robots router.
