paper: FTC-BW: JVN's Mechanical Design Calculator revised for FTC
gearbox
gear
design
ftc
calculator
spreadsheet
ratio
mechanism
Thread created automatically to discuss a document in CD-Media.
FTC-BW: JVN’s Mechanical Design Calculator revised for FTC
by: BenjaminWard
Spreadsheet which helps with the design of robot mechanisms & drivetrains which use DC motors. (FTC)
This is a FTC-revised version of the the “JVN Gearing Spreadsheet” which can be used to help design robot mechanisms & drivetrains which use DC motors.
Original (FRC): https://www.chiefdelphi.com/media/papers/3188
Thanks, JVN!
FTC-BW-JVN-DesignCalc.20170820.xlsx (524 KB)
Re-uploaded to fix incorrectly-sized cells from the Google Drive export (causing a bunch of text to be hidden). I also removed the extraneous named ranges that were part of the deleted Vex/WCP sheets, and fixed the Motors/Specs ranges so that there wasn’t a bunch of extra blank entries in the dropdown list.
I get an error indicating either the page is not found or private, when I click on the calculator link above. How do I get access to the jvn for FTC calculator. I am coach trying to help my team figure out a way to calculate a better gear ratio for their landing mechanism with linear screw.
