Hello, I just wanted clarification on a couple of things.
first, compression: what is it?
I have read in some articles that if it is 0 there is an issue but I don’t have it.
second, third and fourth, particle filters: I at first thought that the vector analysis report ordered the targets by score but now it is apparent they are from the top right and i need to do that manually if i want the feature?
Also, if I only use a single step filter it seems to remove particles outside or inside my criteria but if i use a multiple step filter they all remain. To counter this, i have been using multiple filters (is there a way to fix this so i can use one?) which brings me to my last question-
at some point i messed up my code and had to fix some things. What is below does not work but i have a working version. the working version merely does not have the second filter but i do not know what is wrong with this. The issue is that the code gets hung up in the first iteration of my ‘while(IsAutonomous() && IsOperatorControl())’ loop. the suspect filter and it’s criteria are highlighted in yellow
AxisCamera &canICam = AxisCamera::GetInstance("10.16.71.11");
canICam.WriteBrightness(50);
canICam.WriteWhiteBalance(AxisCamera::kWhiteBalance_Hold);
canICam.WriteResolution(AxisCamera::kResolution_320x240);
canICam.WriteColorLevel(50);
canICam.WriteCompression(0);
//lower easier on CRIO and harder on cam
canICam.WriteMaxFPS(5);
Threshold threshold(RL,RH,GL,GH,BL,BH);
ParticleFilterCriteria2 criteria] = {IMAQ_MT_BOUNDING_RECT_HEIGHT, 0, 15, false, true};
ParticleFilterCriteria2 criteria2] = {IMAQ_MT_AREA_BY_PARTICLE_AND_HOLES_AREA, 0, 74, false, false};
//Set this element to TRUE to indicate that a match occurs when the measurement is outside the criteria range.
BinaryImage *thresholdImage = img->ThresholdRGB(threshold); // get just the red target pixels
delete img;
BinaryImage *filteredImage = thresholdImage->ParticleFilter(criteria, 1); // find the rectangles
delete thresholdImage;
BinaryImage *biFilteredImage = filteredImage->ParticleFilter(criteria2, 1); // find the rectangles
delete filteredImage;
BinaryImage *convexHullImage = biFilteredImage->ConvexHull(false); // fill in partial and full rectangles
delete biFilteredImage;
vector<ParticleAnalysisReport> *reports = convexHullImage->GetOrderedParticleAnalysisReports(); // get the results
