Passing paths to Pathfinder
In WPI Screensteps, it says to use a String k_path_name = “example” to pass into the Pathfinder. How can I change this so it will load paths that I generated from Pathweaver that are stored in a directory called Paths in my robot project? Thanks!
Edit the PathWeaver project to output to the deploy folder of your project. Then in code, use Filesystem.getDeployDirectory() to reference that folder.
