We are having issues using robotpy-pathfinder. When we run our code in autonomous, our robot jitters back and forth. We’ve attached some of our code below. What are some common pitfalls or mistakes implementing pathfinder?
subsystems.py*
class PathFinder():
WHEEL_DIAMETER = 0.5 # 6 inches
ENCODER_COUNTS_PER_REV = 4096 # mag encoder
# Pathfinder constants
MAX_VELOCITY = 11 # ft/s
MAX_ACCELERATION = 6
WHEEL_BASE = (29/12) #29 inches
def __init__(self, points, period, gyro, left_motor, right_motor):
self.gyro = gyro
self.l_motor = left_motor
self.r_motor = right_motor
# self.r_motor.invert()
self.reset()
info, trajectory = pf.generate(points, pf.FIT_HERMITE_CUBIC, pf.SAMPLES_HIGH,
dt=period,
max_velocity=self.MAX_VELOCITY,
max_acceleration=self.MAX_ACCELERATION,
max_jerk=120.0)
# Wheelbase Width = 2 ft
modifier = pf.modifiers.TankModifier(trajectory).modify(self.WHEEL_BASE)
# Do something with the new Trajectories...
left = modifier.getLeftTrajectory()
right = modifier.getRightTrajectory()
leftFollower = pf.followers.EncoderFollower(left)
leftFollower.configureEncoder(
self.l_motor.getRawPosition(), 4096, self.WHEEL_DIAMETER)
leftFollower.configurePIDVA(1.0, 0.0, 0, 1 / self.MAX_VELOCITY, 0)
leftFollower.segment = 0
rightFollower = pf.followers.EncoderFollower(right)
rightFollower.configureEncoder(
self.r_motor.getRawPosition(), 4096, self.WHEEL_DIAMETER)
rightFollower.configurePIDVA(1.0, 0.0, 0, 1 / self.MAX_VELOCITY, 0)
rightFollower.segment = 0
self.leftFollower = leftFollower
self.rightFollower = rightFollower
def reset(self):
self.l_motor.resetPostion()
self.r_motor.resetPostion()
self.gyro.reset()
def calculate(self):
lvel = self.leftFollower.calculate(
self.l_motor.getRawPosition())
rvel = self.rightFollower.calculate(
print("l: {}".format(self.l_motor.getRawPosition()))
print("r: {}".format(self.r_motor.getRawPosition()))
gyro_heading = -self.gyro.getAngle()
desired_heading = pf.r2d(self.leftFollower.getHeading())
angleDifference = pf.boundHalfDegrees(desired_heading - gyro_heading)
turn = 0.8 * (-1.0 / 80.0) * angleDifference
lvel = lvel + turn
rvel = rvel - turn
# -1 is forward, so invert both values
return -lvel, -rvel
robot.py
import wpilib
from subsystems import HiroChassis, HiroLauncher, HiroElevator, HiroPathfinder
class Hiro(wpilib.IterativeRobot, wpilib.TimedRobot):
def robotInit(self):
self.buttons = wpilib.Joystick(0)
self.joystick = wpilib.Joystick(1)
self.chassis = HiroChassis()
self.launcher = HiroLauncher()
self.elevator = HiroElevator()
self.pathfinder = HiroPathfinder(self.getPeriod())
def autonomousInit(self):
self.pathfinder.reset()
def autonomousPeriodic(self):
l, r = self.pathfinder.calculate()
self.chassis.tankDrive(l, r)
# self.chassis.tankDrive(-0.5, -0.5)
def teleopPeriodic(self):
self.chassis.update(self.joystick, self.buttons)
self.launcher.update(self.joystick, self.buttons)
self.elevator.update(self.joystick, self.buttons)
def testPeriodic(self):
wpilib.LiveWindow.run()
if __name__ == "__main__":
wpilib.run(Hiro)
I know this is in python, but it should be very similar to Java.
Also, motor.getRawPosition is the same as getQuadraturePosition.
The encoders are directly connected to the TalonSRXs.
