I’ve only programmed West Coast drivetrains. Does anyone have any resources for pathplanning with a mecanum drivetrain, on the off-chance my team uses it this year? I’d like to be able to strafe in a path.
I would definitely prefer to use Pathweaver and Jaci’s Pathfinder if possible. Thank you!
Greetings,
Mecanum is rather difficult to use with pathfinder for one specific reason: wheel slip. It’s very difficult to determine where you are when your wheels slip as much as mecanum’s due. IF you wanted to get around this, a spring loaded set of omni wheels have been used by some teams to try and get reasonable feed back for pathfinding.
Mecanum’s pretty great from a controls side of things - it’s holonomic so you can straight up just PID your three states (x,y,\theta) along the profile. Though, as @wilsonmw04 said, localization’s the hard part. Sprung omnis is a fairly simple solution, but also if you properly characterize your drivetrain, you should be able to come up with a fairly accurate position estimator. Might take a bit of work, though.
I’ve never done mecanum before, so I can’t speak to the accuracy of this. However, I did remember a thread on here a while back talking about being able to do accurate odometry with mecanum wheels so long as you don’t strafe:
I know the OP wants to strafe, but if you’re unable to use drop-down omnis for some reason then this may be a viable option.
