PathPlanner 2025
The first PathPlanner realease of the 2025 season is now available! You can download the latest version from here, and install PathPlannerLib through VSCode. If you used the 2025 beta, you will need to remove the beta vendor json and install the stable version again.
Documentation available at pathplanner.dev
I’m going to summarize all the new features of the 2025 version below, most of this will be copied from the beta thread.
This release includes a ground-up rework of PathPlanner’s trajectory generation, which aims to solve the shortcomings of the previous iteration and attempts to give PathPlanner trajectories a “just works” quality with little to no tuning, all while maintaining the ability to generate trajectories on-the-fly.
Improvements of Trajectory V2
Respects Swerve Dynamics
Trajectories are now generated with swerve kinematics/dynamics in mind to make sure each state is within the robot’s capabilities, increasing path following accuracy and consistency.
Motor Torque Based Acceleration Limits
Trajectory V2 uses the available torque output of your robot’s drive motors to limit the acceleration and deceleration along the trajectory. One of the issues with limiting acceleration of a module or the robot as a whole with a constant maximum acceleration/torque is that the robot’s drive motors are unable to provide constant torque throughout its entire RPM range. Therefore, they cannot maintain a linear acceleration, which requires the user to either reduce the maximum acceleration or velocity below the true maximum capabilities of the robot, or risk the robot falling behind the target acceleration when already near the max velocity. Essentially, you would have to choose between high speed or high accuracy.
Trajectory V2 now limits the acceleration of each module based on the maximum possible torque output of its motor. This uses the motor’s current RPM and current limit to get the true maximum torque output of the motor. The robot as a whole will only accelerate as much as the torque outputs from each motor would allow for. Furthermore, forces within the module due to friction are taken into account, which further limits the robot’s acceleration but aids in deceleration.
Arbitrary velocity/acceleration constraints can still be used via global constraints or constraint zones, and they will further limit the robot’s motion as long as the arbitrary constraints are within the robot’s capabilities.
Traction Control
The maximum torque applied by each drive motor is limited by the force of friction between the wheels and the carpet to prevent wheel slip. Furthermore, the maximum speed in curves is limited to prevent the wheels from slipping due to the centripetal forces it experiences.
Balanced Translation and Rotation
Translation and rotation speed is balanced to ensure that every rotation target is hit. The robot will now be able to slow down to give enough time for a rotation to complete.
Torque-Current Feedforwards
During generation, torque-current feedforwards are calculated at every state. Path following commands can now output these feedforwards along with the normal ChassisSpeed output, allowing Phoenix Pro teams using TorqueCurrentFOC control modes to utilize these values to further increase path following performance and accuracy. For teams using voltage output, the module’s acceleration is also provided, which can be converted to a voltage feedforward using the characterized kA value.
Other Notable Changes Since 2024
Path Optimization
The path editor now includes a path optimizer tool that uses a genetic algorithm to adjust the shape of the path, minimizing the total trajectory runtime. The optimizer is not guaranteed to find the true “optimal” path shape, but it can still significantly improve the runtime of unoptimized paths. The optimizer can be run for multiple iterations if better results are desired.
GIF/PNG Export
The ability to export a path as an animated GIF or PNG image has been added. This can be used to easily share auto animations, create auto printouts for competition, etc.
pathplanner
Zoned Event Markers & Event Triggers
Event markers now have the option of including an end position. If a marker is zoned, its associated command will start when the robot enters the zone, and be stopped when it exits the zone. Event markers can now also be used as triggers based on the name they are given in the GUI. For zoned markers, event triggers will remain high while within the zone, and go low when leaving. If a marker is unzoned, its trigger will go high for one loop. Using events as triggers allows for much more complex behavior than NamedCommands, by binding different commands to a marker going high/low, combining multiple event triggers together to handle overlaps, or combining event triggers with other custom triggers to react to sensor reading, for example.
“Point Towards” Zones
Point towards zones are zones within a path where the robot should aim at a target position on the field. For example, this can be used to track a goal position while following a path. Overriding rotation feedback while in this zone can further increase aiming accuracy.
PathPlannerAuto Triggers
Allows for creation of event triggers, point towards zone triggers, and more on a per-auto basis instead of globally for all path following commands. This can be used to create more complex auto functionality via triggers instead of a monolithic command composition.
Robot Features
The ability to add custom shapes to the robot preview to represent different robot features has also been added. This can be used to represent things like intakes to make path creation a bit easier, or can be used to draw pretty much anything on the robot preview. Currently, features can be added as a rectangle, circle, or line. The robot’s bumpers can now also be offset from the center of the robot’s drivetrain.
Replanning Removed
Path replanning has been removed for various reasons. First and foremost: it seemed to cause more issues than it solved. It is very difficult to create a generalized replanning solution that works for everybody. Everyone expects it to work a little bit differently, and it can’t really work perfectly for everyone. It tended to cause a lot of confusion for some people, so I think it is best to remove the generalized solution and leave any complex replanning up to individual teams to implement according to their needs if they want such a feature. Furthermore, the computation requirements for trajectory generation has significantly increased. Teams heavily relying on replanning to stich their autos together would experience noticeably higher generation time if they were constantly generating new paths throughout auto mode instead of using the pre-generated “ideal” trajectory.
Torque-Based Swerve Setpoint Generator (Currently Java Only)
A custom version of FRC team 254’s SwerveSetpointGenerator which generates setpoints based on available motor torque instead of a maximum acceleration. Also includes various other limits carried over from the generation algorithm, such as limiting torque to maintain traction and limiting module heading changes to prevent sliding. This implementation uses the same configuration object as trajectory generation, making setup quick and easy.
Override Correction Feedback
Methods have been added to PPHolonomicDriveController that allow for overriding the X, Y, and rotation feedback/correction while path following. This can be used to correct the robots X/Y velocity or rotation velocity to target a game piece or goal, while still using the feedforward velocities from the trajectory.
Good luck to everyone in Reefscape!
Are you opposed to teams using the new Vendor Dependency Manager as a much easier way to install the PPLib vendordep?
Installing via Install Libraries (online) is not the current recommendation (but it will still work).
No, documentation just needs to be updated to refer to that instead. Working on a PR to add the vendor json to the manager repo now.
Awesome let me know if we can help!
When will the map be updated? (if it hasn’t already)
EDIT: map is read as field…there is only one on the documentation…
It looks like the barge zone colors are flipped on the path planner field map
P.S. Thanks @Ryanvdaa for pointing out!
Fixed. You’ll have to redownload from the release page.
Will a path be mirrored or rotated when using a path on blue vs. red as this year’s map has rotation symmetry, unlike last year?
It will be rotated, still maintaining a blue origin.
I created a path with a starting point, an ending point, and an interior waypoint.
When I add a rotation target at position=0.5, it works perfectly.
But when I make the position anything greater than 1.0, the rotation target is gone: it’s not shown on the UI and the robot’s heading doesn’t change correspondingly
I am using v2025.1.1
path file.zip (806 Bytes)
I believe that the way that the rotation targets work is that the 0.5 position is how far through the path you want the rotation target to be. This would mean that 0.5 position is telling the rotation target to be 50% of the way through that path. Also, that would mean that the 1.07 position would be saying that the rotation target would be 107% through the path, which doesn’t exist.
Thanks for answering!
I’ve deleted the path and created an identical one, and have successfully added the rotational target.
Note that this isn’t exactly right though. If a path is created with three waypoints (start-interrior-end), position=0.0 will be the starting point, position=1.0 will be the interior point and position=2.0 will be the ending point. Here I’ve created a rotational target with position = 1.48, which lies between the interior waypoint and the ending point
So this would mean that 1.0=50% of path completed and 2.0=100% of path completed?
What was the problem then that wasn’t allowing the rotation target from generating in the first path that you created?
How should you initialize the previous setpoint’s drive FFs assuming the robot is currently moving?
Will initializing it with zeros change anything in the setpoint generation?
I’m assuming there’s some weird bug based on when/how you add waypoints and rotation targets that caused that, which is why it worked in another path. If you end up finding exactly how to reproduce it, let me know.
They’re not used by the generator, so they can be anything. Initializing to zeros is probably the safest option to prevent something weird from being output.
Should swerveModuleState.optimize() happen after getting a setpoint from the setpoint generator, or is that redundant/problematic?
You would have to optimize them yourself since the generator doesn’t know what the actual module states are.
Doesn’t it know the previous ones? Which were initially reset to the actual module states.
Yes. They are technically optimized against those states, but there’s no guarantee that those states are the actual modules states like you would have from reading the sensors directly. You could set them to anything, not reset them after not using the generator for a while, etc.
So, to just make sure they’re always optimized, it’s good to do it yourself.
public static RobotConfig fromGUISettings() throws IOException, org.json.simple.parser.ParseException
Load the robot config from the shared settings file created by the GUI
Returns:
RobotConfig matching the robot settings in the GUI
Throws:
IOException - if an I/O error occurs
org.json.simple.parser.ParseException - if a JSON parsing error occurs
Above is the java docs for the pathplanner .fromGUISettings() but whenever we try and add the method in our code we get a IO Exception. Is there a way to approach this error because the file we got from settings.json is the file derived from the pathplanner settings robotConfig.
