Pathplanner AutoChooser remembers deleted autos
I made some experimental autos using pathplanner and deleted them all and replaced them with new ones, but the Autochooser builder are still showing up in the dashboard on a real robot, but not the simulator
See this warning at the bottom: Build an Auto | PathPlanner Docs
This method will load all autos in the deploy directory. Since the deploy process does not automatically clear the deploy directory, old auto files that have since been deleted from the project could remain on the RIO, therefore being added to the auto chooser.
To remove old options, the deploy directory will need to be cleared manually via SSH, WinSCP, reimaging the RIO, etc.
Thank you and also
I can not delete the files I get a Permission Denied
How do I get Permissions? I’m Logged in ad lvuser
If you are using putty there is a way to do it. Log in as admin, move out one set of folders, go to lvuser folder, and clear it. One of my mentors taught me that.
I had this issue using Filezilla, i ran as admin and it worked
I believe you can also reformat your Robo Rio, and then deploy your code on it again
One of my programming students showed me we can use windows file explore
Enter
ftp://[email protected].AM.or
When prompted select log in anonymous
Browse to home/lvuser
Delete deploy folder
