Hello,
My team just came in contact with a possible bug where we can’t get path planner to run without giving us a json parse error. We are using AutoBuilder and worked perfectly before updating to the newest version. Now it doesn’t even work at all even after rolling back the update.
Our Code is: https://github.com/Isotope-Robotics/FRC-2024
The Error is: * ********** Robot program starting **********
NT: Listening on NT3 port 1735, NT4 port 5810
NT: Got a NT4 connection from 10.97.9.19 port 58960
NT: CONNECTED NT4 client ‘photonvision@1’ (from 10.97.9.19:58960)
NT: Got a NT4 connection from 10.97.9.224 port 55078
NT: CONNECTED NT4 client ‘DartClient_80094481@2’ (from 10.97.9.224:55078)
NT: Got a NT4 connection from 10.97.9.224 port 55079
NT: CONNECTED RTT client (from 10.97.9.224:55079)
Photon Vision is Ready to Roll!!
Unhandled exception: org.json.simple.parser.ParseException: Unexpected token RIGHT BRACE(}) at position 788.
Error at org.json.simple.parser.JSONParser.parse(JSONParser.java:107): Unhandled exception: org.json.simple.parser.ParseException: Unexpected token RIGHT BRACE(}) at position 788.
The robot program quit unexpectedly. This is usually due to a code error.
The above stacktrace can help determine where the error occurred.
See Reading Stacktraces — FIRST Robotics Competition documentation for more information. -
The startCompetition() method (or methods called by it) should have handled the exception above.
at org.json.simple.parser.JSONParser.parse(JSONParser.java:59)
at org.json.simple.parser.JSONParser.parse(JSONParser.java:53)
at com.pathplanner.lib.auto.AutoBuilder.buildAuto(AutoBuilder.java:735)
at com.pathplanner.lib.commands.PathPlannerAuto.(PathPlannerAuto.java:39)
at com.pathplanner.lib.auto.AutoBuilder.buildAutoChooser(AutoBuilder.java:661)
at com.pathplanner.lib.auto.AutoBuilder.buildAutoChooser(AutoBuilder.java:637)
at frc.robot.RobotContainer.(RobotContainer.java:27)
at frc.robot.Robot.robotInit(Robot.java:66)
at edu.wpi.first.wpilibj.TimedRobot.startCompetition(TimedRobot.java:107)
at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:365)
at edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:453)
at frc.robot.Main.main(Main.java:27)
Warning at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:379): The robot program quit unexpectedly. This is usually due to a code error.
Error at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:386): The startCompetition() method (or methods called by it) should have handled the exception above.
