Sorry, unfortunately I’m not in charge of the repository so I can’t make it public. But here is the contents of the file:
package frc.robot.commands.drive;
import java.util.ArrayList;
import com.pathplanner.lib.PathConstraints;
import com.pathplanner.lib.PathPlanner;
import com.pathplanner.lib.PathPlannerTrajectory;
import com.pathplanner.lib.PathPoint;
import com.pathplanner.lib.PathPlannerTrajectory.PathPlannerState;
import edu.wpi.first.math.controller.HolonomicDriveController;
import edu.wpi.first.math.controller.PIDController;
import edu.wpi.first.math.controller.ProfiledPIDController;
import edu.wpi.first.math.trajectory.TrapezoidProfile;
import edu.wpi.first.math.geometry.Pose2d;
import edu.wpi.first.math.geometry.Rotation2d;
import edu.wpi.first.math.geometry.Translation2d;
import edu.wpi.first.math.trajectory.Trajectory;
import edu.wpi.first.wpilibj.DriverStation;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj2.command.CommandBase;
import frc.robot.subsystems.chassis.DrivetrainSubsystem;
import frc.robot.subsystems.chassis.DrivetrainConstants;
* This command generates a trajectory in the code and follows it
* (as opposed to getting the trajectory from a JSON file).
public class FollowGeneratedTrajectoryCommand extends CommandBase {
private DrivetrainSubsystem drivetrain;
public FollowGeneratedTrajectoryCommand(DrivetrainSubsystem drivetrain) {
this.drivetrain = drivetrain;
this.addRequirements(this.drivetrain);
* This is an arraylist of PathPoints objects that are points the trajectory
* passes through. The start and end poses are mandatory, and you can also
* add additional waypoints in between.
this.kTrajectoryWaypointsList = new ArrayList<PathPoint>();
this.timer = new Timer();
// The position tolerance in X, Y and angle for HolonomicDriveController
// is represented in one Pose2d object.
this.kPositionTolerance = new Pose2d(
DrivetrainConstants.kPositionToleranceMetersX,
DrivetrainConstants.kPositionToleranceMetersY,
Rotation2d.fromDegrees(DrivetrainConstants.kPositionToleranceDegrees));
private Timer timer;
private PathPlannerTrajectory trajectory1;
private PIDController PIDControllerX, PIDControllerY;
private ProfiledPIDController profiledPIDControllerAngle;
private ArrayList<PathPoint> kTrajectoryWaypointsList;
private HolonomicDriveController driveController;
private Pose2d currentPose;
private Trajectory.State currentPositionSetpoint;
private PathPlannerState currentPathPlannerState;
private Rotation2d currentAngleSetpoint;
private Pose2d kPositionTolerance;
@Override
public void initialize() {
// The trajectory is generated in initialize() instead of in the constructor
// because the starting point is the robot's current position.
PathConstraints trajectoryConstraints = new PathConstraints(
DrivetrainConstants.kMaxChassisVelocityMPSAuto,
DrivetrainConstants.kMaxChassisAccelMPSSquared);
* Each point has a:
* -- X and Y in meters as a Translation2d.
* -- A heading (aka direction of travel) as a Rotation2d.
* -- Optionally the orientation of the robot as a Rotation2d.
* -- Optionally a velocity override (aka specifying the velocity
* manually instead of PathPlanner calculating it) as a double.
// Start point
this.kTrajectoryWaypointsList.add(new PathPoint(
this.drivetrain.getCurretnPose().getTranslation(),
// Calculate the angle between the robot's current point and the next
new Rotation2d(this.getAngleFromPoints(
this.drivetrain.getCurretnPose().getX(),
this.drivetrain.getCurretnPose().getY(),
DrivetrainConstants.kTrajectoryEndPose_FieldRelativeXMeters,
DrivetrainConstants.kTrajectoryEndPose_FieldRelativeYMeters)),
this.drivetrain.getGyroRotation()));
// Optional: add more points here
new Translation2d(
DrivetrainConstants.kTrajectoryEndPose_FieldRelativeYMeters),
// Calculate the angle between the robot's previous point and this one
new Rotation2d(180 - this.getAngleFromPoints(
Rotation2d.fromDegrees(DrivetrainConstants.kTrajectoryEndAngle_FieldRelativeDegrees)));
// Now create the trajectory...
this.trajectory1 = PathPlanner.generatePath(
trajectoryConstraints,
this.kTrajectoryWaypointsList.get(0),
this.kTrajectoryWaypointsList.get(1));
DriverStation.reportError("trajectory successfully generated!", false);
// The closed-loop controllers should start from scratch every time the command
// starts, so they're initialised in initialize() instead of the command's
// constructor.
this.PIDControllerX = new PIDController(
DrivetrainConstants.kXControllerP,
DrivetrainConstants.kXControllerI,
DrivetrainConstants.kXControllerD);
this.PIDControllerY = new PIDController(
DrivetrainConstants.kYControllerP,
DrivetrainConstants.kYControllerI,
DrivetrainConstants.kYControllerD);
this.profiledPIDControllerAngle = new ProfiledPIDController(
DrivetrainConstants.kAngleControllerP,
DrivetrainConstants.kAngleControllerI,
DrivetrainConstants.kAngleControllerD,
new TrapezoidProfile.Constraints(
DrivetrainConstants.kAngleControllerMaxVelocity,
DrivetrainConstants.kAngleControllerMaxAccel));
// Angle is measured on a circle, so the minimum and maximum values are
// the same position in reality. Here the angle is measured in radians
// (I think) so the min and max values are 0 and 2PI.
this.profiledPIDControllerAngle.enableContinuousInput(0, Math.PI * 2);
// HolonomicDriveController accepts 3 constructor parameters: two PID
// controllers for X and Y, and a profiled PID controller (TrapezoidProfile)
// for controlling the angle.
this.driveController = new HolonomicDriveController(
this.PIDControllerX,
this.PIDControllerY,
this.profiledPIDControllerAngle);
this.driveController.setTolerance(this.kPositionTolerance);
this.driveController.setEnabled(true);
this.timer.reset();
this.timer.start();
@Override
public void execute() {
// The trajectory has a position, angle, velocity and acceleration for each
// point in time since start. This is represented in a Trajectory.State object.
// We don't use this angle, instead we use the one from PathPlanner.
this.currentPositionSetpoint = this.trajectory1.sample(this.timer.get() + 0.02);
// basically the same thing, but with PathPlanner, so it has information about
// the angle for a holonomic robot (which the WPILib trajectory doesn't).
// This is possible because PathPlannerTrajectory extends the WPILib Trajectory,
// and PathPlannerState extends the WPILib Trajectory.State.
this.currentPathPlannerState = (PathPlannerState) this.trajectory1.sample(this.timer.get() + 0.02);
this.currentAngleSetpoint = this.currentPathPlannerState.holonomicRotation;
this.currentPose = this.drivetrain.getCurretnPose();
// The HolonimicDriveController.calculate() method returns the desired
// ChassisSpeeds in order to reach the current setpoints. This is then
// passed to the DrivetrainSubsystem.drive() method.
this.drivetrain.drive(
this.driveController.calculate(
this.currentPose,
this.currentPositionSetpoint,
this.currentAngleSetpoint),
true);
@Override
public void end(boolean interrupted) {
this.timer.stop();
this.timer.reset();
this.driveController.setEnabled(false);
@Override
public boolean isFinished() {
// Returns true if the time the trajectory takes to drive
// has passed, and driveController is at it's setpoint or
// within the position tolerance for it.
return (this.trajectory1.getTotalTimeSeconds() < this.timer.get()
&& this.driveController.atReference());
private double getAngleFromPoints(double x1, double y1, double x2, double y2) {
return Math.PI / 2 - Math.atan2(y2 - y1, x2 - x1);
