PathPlanner
Hello, I am trying to use PathPlanner for autonomous but I am running into these errors:
“The type Swerve does not define getRobotRelativeSpeeds() that is applicable here”, " The type Swerve does not define drive(ChassisSpeeds) that is applicable here".
My code is based off of BaseFalconSwerve: GitHub - ManOfAgua/SwerveUpdated
With the changes to the PathPlanner autobuilder, you’ll need to provide methods with ChassisSpeed. Here is what I used, but it may be slightly different drive method for the BaseFalconSwerve.
This method would be within the swerve subsystem, correct?
