Pathweaver right side driving the opposite way
We are using SparkMax motor controllers and when following a straight path, the ride side motors seem to be inverted. Is there a quick way to fix this?
If it’s following the path correctly but is just inverted, then flip the encoder count (using the appropriate method based on the way you are reading them) and then flip the motor output for the path follower.
