PathWeaver Vendor Dependecy Issuses
I am having troubles with adding Pathfinder as a vendor dependency. I copied the vendor dependency link from the WPI screen steps then pasted it into the Command Palette under, Manage Vendor Libraries -> Install new Library online. Then, I go to check if the library is installed by Manage Vendor Libraries -> Manage Current Libraries and it is not there. What am I doing wrong?
Screen Steps :http://wpilib.screenstepslive.com/s/currentCS/m/84338/l/1021631-integrating-path-following-into-a-robot-program
Earlier I was getting a forbidden error downloading the json file but now it’s working. Try again.
I am not getting any errors, but it still does not show it is downloaded.
Just to ensure you got the correct file, here is the link:
https://dev.imjac.in/maven/jaci/pathfinder/PathfinderOLD-latest.json
If you copy the link address and go to Manage Vendor Libraries → Install New Library Online, copy in the link there(I assume you’ve already done that). If that doesn’t work, I’ve attached a copy of the Pathfinder.json file. If you download this and put it into the following file folder, you should be set to go: C:\Users\Public\frc2019\vendordeps
Paste the json file in there, go to Manage Vendor Libraries->Install New Library Offline, and the file should pop up.
PathfinderOLD.json (2.6 KB)
There were some webserver issues. Try again.
