Pbasic 2.5 ?
I downloaded the 2.5alpha editor off of InnovationFirst.
However, it doesn’t seem to be PBasic 2.5
I tried something like this:
if vari > 25 then vari=30
If I am not mistaken, PBASIC 2.5 was supposed to allow commands like this. However, I still get “Expected a label” when I check syntax. Same thing with a multiline command. I “Expected a little different” from this editor. The program version under “Help>About” reads “2.0 Alpha © 1998-2003”. This is a very recent release, but is it still not what we hoped for?
I tried exactly the same command and had no errors - are you sure you’re using 2.5 code? When I drag FIRST’s 2.5 code into a 2.0 editor, the commented line " ’ {$PBASIC 2.5} " caused an error - could it be that you need that to jump into V. 2.5? I can’t think of any reason why that would actually make any sort of difference, but it’s worth a try if you don’t have FIRST’s commented initialization at the top of your code.
Did you add the {$PBASIC 2.5} directive?
*Originally posted by gwross *
**Did you add the {$PBASIC 2.5} directive? **
Yeah, I think he’s right. If you are using the newest software but it thinks that you are using an old stamp it should keep you from using the newer commands.
Sheepish grin …no.
Thanks alot!
Update: I added the directive and now it works!! now-excited grin
