We are trying to use Pneumatics for the first time and believe we have the PCM wired correctly. When enabled we have the strobe flashing green light on status but none of the output Solenoid LED’s under the ports will light up. Any ideas as to the issue, Coding? Wiring? or possibly a dead PCM…
we have 24V Festa Double solenoids and switched the PCM to 24V bridge, but cannot send voltage to the outputs anyone have similar issues.
Thanks for your help/insight
It is probably coding. What language are you using? LabVIEW has examples that you can run that will allow you to turn on and off 1 solenoid each time it is run.
We are in java code. Will post below, We hardwired the solenoid to at 24V battery series and got it to light up, also manual fired the Solenoids with the blue screws at the top.
