PDP Reading Incorrectly over CAN
We are trying to use the PowerDistributionPanel Java class to read the current from the PDP. The Current readouts are much, much higher than they should be, but only on channels that seem to be incorrect at random. For example, the overall current for the board is usually around 30 amps, with channel 2 around 23 Amps. The temperature and voltage readouts seem correct. Any ideas?
Which thread would you like the responses to be posted to?
This one:
http://www.chiefdelphi.com/forums/showthread.php?t=133169
or this one?
http://www.chiefdelphi.com/forums/showthread.php?t=133172
