I don’t know for sure the answer without research since I don’t use this stuff much. I think the FRC docs describe the CAN devices standards for FRC. I believe the unique CAN address on a bus is the manufacturer, model, and CAN id. And you have which bus it is. But bear in mind that in some circumstances duplicate CAN addresses are allowed and may or may not work right such as when identical new Talons are put on the bus and you need to configure them. That may or may not work - you may have to do one at a time. (Confusing!)
Note that I do not have a DynID (see my info below). Maybe I’m a little behind updates (but I can’t be too far behind) or it’s just for CANivore which I don’t have here at home (it’s locked in the school for the summer). Most likely my info is the up-to-date version and the CTRE document is many years behind; I think they changed their format and my example is right.
If you are putting this information in a program and have never done this before, I have a (crude) Java program to retrieve similar data and parse JSON from GRIP from years ago. If you are starting at zero that could be helpful (or not) and I’ll put it here if you want.
Also, CTRE (can’t remember who maybe Ozrien?) posted a program here in CD that you can run in robotInit to find all the devices on the CAN bus. That might be better for whatever you are trying to accomplish.
Also, the Phoenix server doesn’t start if you have no CTRE motor controllers in use. In that case add a Talon to your program or start the temporary server with the Tuner.
http://roborio-4237-frc.local:1250/?action=getdevices
“BusUtilPerc”: -1.0,
“DeviceArray”: [
“BootloaderRev”: “2.6”,
“CANbus”: “rio”,
“CANivoreDevName”: “”,
“CurrentVers”: “22.0”,
“HardwareRev”: “1.4”,
“ID”: 0,
“ManDate”: “Nov 3, 2014”,
“Model”: “Talon SRX”,
“Name”: “Leader”,
“SerialNo”: “00000000000000000000000000000000”,
“SoftStatus”: “Running Application.”,
“SupportsConfigs”: true,
“Vendor”: “Cross The Road Electronics”
“CANbus”: “rio”,
“ID”: 1,
“Name”: “Follower”,
“BootloaderRev”: “3.1”,
“CANbus”: “rio”,
“CurrentVers”: “1.40”,
“HardwareRev”: “Smart Module 1.1, Baseboard 1.3”,
“ID”: 0,
“ManDate”: “July 14, 2015”,
“Model”: “PDP”,
“Name”: “PDP (Device ID 0)”,
“SerialNo”: “00000000000000000000000000000003”,
“SupportsConfigs”: false,
“GeneralReturn”: {
“Action”: “getdevices”,
“CANbus”: “”,
“Error”: 0,
“ErrorMessage”: “CTRE_DI_OKAY”,
“ID”: 0,
“Model”: “”
