So we have the license, we activated the license, the team number is in agreement with the program, but we are still getting this error. I believe this error is causing the entire program to fail as well.
Your devices in TunerX seem to have the LIC icon. If properly licensed I believe they have the Pro icon. We ran into this last year when the team number was not properly set.
It looks like you did it thru RIO imaging tool. I think there is a way to do it in Visual Studio. Might try that way. I don’t know the exact method but I am sure it’s pretty easy to look up.
Nice catch! As seen below, the device says “Not Licensed” even though I activated the 2025 license on the device. @daltzsmith - Any ideas here?
For setting the team number on the roboRIO, since this is done through Tuner X Preview, that shouldn’t be causing this “Not Licensed” issue, right? As in, I should be able to activate a license on a device before ever deploying code, right?
Good thinking! I did have a brand new VH-109 which was not configured to our team number. So I went through the configuration for our team number, redeployed the code, and now I do not get the error as stated originally in this thread. Not sure how that would be related, but that is the update.
HOWEVER, in Tuner X Preview, the device is still showing as “Not Licensed” when I have activated my 2025 license. So - error is gone when deploying code - but devices are continuing to not acknowledge the licensing.
Cool! I love learning new tips and tricks from everyone here! To help, I took a screenshot when first opening this tool and then again after setting the team number through this tool. Sadly, no change to the “Pro” licensing status for the devices.
NOTE: CTR Electronics is closed for the holidays through Wed, January 1st.
Support and Sales requests will be processed when staff returns on January 2nd.
I believe this is where the problem is. We normally connect over the robot network either WiFi or Ethernet and then configure TunerX with our team number.
I imagine when you directly connect to the CANivore USB the devices don’t show as PRO licensed since it doesn’t know what team number your robot is configured for as the CANivore is not connected to a RIO at the time.
