If I run out code to RoboRio by running the RobotMain.vi then start Phoenix tuner I immediately get a “Lost Connection to Target” error on Labview and code stop executing.
This is over the USB tether and same over wireless connection.
If I start Tuner then try to run out code I get an error that the target won’t respond.
Anyone seeing the same thing?
Tuner will run with with code deployed to RoboRio but that is hugely inconvenient.
what are you doing to “start” the phoenix tuner? If you are manually clicking “start a server” that would make you lose connection to the robot(I’m pretty sure, I have never tried it for myself). If you are just opening the phoenix tuner and that problem is occuring, I really have no idea what is happening.
Okay, so I will be in robotics in about 20 min and if there isn’t any solutions by then, I will try and imitate the problem. Can’t tell what would be causing the problem. suggest redownloading in the meantime.
