I have PhotonVision installed on a OrangePi 5 using an Arducam OV9281 USB Camera.
After calibration I get target X and Y values that don’t match what I expected. I was assuming this would map to distance from camera to the AprilTag. When target X says 1.0 meter and is center of captured image I am actually only about 0.64 meters away from the camera.
I have tried calibrating the camera using both calibdb and the Photonvision calibrator and get the same results.
When I calibrated with the Photonvision calibrator I am using the 8x8 checkboard and 1" size. I have verified that the checkboard cells are 1" and square.
Is this the result I should expect?
