Photon vision field resource
Where do I find the AprilTagFields.k2023ChargedUp.m_resourceFile that is used in this photon vision example code for getting the field position?
AprilTagFieldLayout aprilTagFieldLayout = AprilTagFieldLayout.loadFromResource(AprilTagFields.k2023ChargedUp.m_resourceFile);
It’s in the latest WPILib. Make sure you’re updated to the latest in your robot code (install it on your laptop as well).
It still gives me the error:
unhandled exception type IOException
even after I updated it.
It throws a checked exception so you need a try/catch.
    AprilTagFieldLayout layout;
    try {
      layout = AprilTagFields.k2023ChargedUp.loadAprilTagLayoutField();
    } catch(IOException e) {
        // TODO decide what you want to do if the layout fails to load
