Photonvision cant see coprocessor (happened after pathplanner update)
The name in photonvision is the same as the one I use in code. I am using a static IP address and I’ve verified that my coprocessor is setup as a static IP address, it is on 10.12.66.11. I am able to wirelessly access photonvision.local:5800 yet whenever I run my code I get
PhotonVision coprocessor at path/photonvision/camera not found on NetworkTables. Double check that your camera names match!
Found the following PhotonVision cameras on NetworkTables:
camera
I’ve restarted photonvision aswell as tried using DHCP but nothing works. It was all working fine until I updated pathplanner to the latest version. Once I did that I started getting the errors. My coprocessor used to be a read only file system but I reflashed it and set it up to not be read only aswell as setting up the static IP address to 10.12.66.11.
I am on the latest version of WPIlib, pathplanner, and photonvision on the coprocessor side aswell as PhotonLib.
Seems funky.
FWIW, in the latest version, here’s the code that triggers that error:
Basically, the error happens when photonlib connects to network tables and can’t specifically find a valid heartbeat entry in the table. However, the response of “what did I found” goes back up one layer, and just looks for subtable names under /photonvision. This mismatch causes the confusing error.
While I’m not positive what would drive this symptom, the only way I can think that error message would be generated is if photonvision is indeed running on the processor and on the network, but the heartbeat entry isn’t getting updated.
EDIT: Per discord this is actually already known. There’s an issue in how we’re subscribing to topics such that requesting a list of topics includes the subscription to the non-existent topic. Same debug steps though.
In the photonvision UI, are you seeing camera feeds and identifying targets?
Can you connect in outlineviewer, and send a screenshot of what’s in the table?
Yes, in the photonvision UI I am seeing camera feeds and it is identifying Apriltags
It shows that the camera exist and is seeing a target aswell
My team had a similar but not ideantical issue which was caused by a mismatch of photon vision version and WPIlib/photonLib version? Could we see your code/library versions and the version of photon vision your co-processor is running?
Everything is up to date including photonvision on version 2023.4.2
Additionally, it seems to recognize in terms of errors if it sees an apriltag or not. When it is seeing one it will give a new error saying that im not setting a reference pose when i try to use it even though I do and it doesnt error when its not seeing an apriltag
Solved, I built with WiFi and redeployed and that fixed it.
