Does anyone has same problem like this?
Have installed PhotonLib into Vscode,and installation looks OK,but cannot build successfully. and error information as below:
Could anyone help me please?
Would you please make sure you have internet connection and try the build again?
I have confirmed that there is no problem with the network connection, and I have rebuild it. The problem is still there.
Are you able to access those websites from a browser on the build machine?
The URL you sent seems to work for me:
https://maven.photonvision.org/repository/internal/org/photonvision/PhotonLib-cpp/v2023.1.1-beta-5/PhotonLib-cpp-v2023.1.1-beta-5.pom
resolves to this
Yes,I can.I am using a VPN.
Hmmm. Tentatively confirmed that the url shouldn’t be blocked behind the great firewall, so not thinking that’s involved.
I do wonder if the VPN config is playing tricks on gradle though? Does turning it on and off make a difference?
Thank you for reply,it makes no difference whether the VPN is on or off , same error information.
You can try building photonlib from source yourself then? Clone photonvision and run ./gradlew publishtomavenlocal
. Then add mavenlocal to the repositories block of your robot project:
repositories {
<snip>
mavenLocal()
errr,how to clone Photonvision to local?
I go to my CPP programm and run ./gradlew publishtomavenlocal
. but it shown:
Ah, you are trying to build your robot code with photon lib, not build photon vision.
Did you install it using the wpilib extention? If so try it in a wpilib example project and see of it builds
Oh,as soon as I add the Photon Vision library, I get the above error whenever I build the program.
