Generally, I can get photonvision to work well.
But when I restart my computer, vscode can no longer find the vendor library for photonvision. The file is there, and I’ve made no modifications to it. But for some reason vscode can’t find it. The solution I’ve found is to delete the file in vendor libs and reinstall the library.
Is there any solution so this doesn’t happen every time I restart my computer?
Can you share the specific build output that shows the error you’re referring to? I don’t doubt that you’re having issues, but I do doubt that the cause is because it thinks the json file in vendordeps doesn’t exist
