When we try to use the .getBestCameraToTarget() function on an AprilTag it always returns 0,0,0 in the Transform3d. When I try to use other functions from the photonvision (like .getFiducialId()) it returns it as its supposed to. The Code:
Thank you!
You are in 2D processing mode, you’ll need to calibrate your camera for your desired resolution and switch to 3D mode.
