Networking setup? Interested to see if an older release works…
Still possible.
Still possible.
no matter what settings you have, you’ll be able to connect to photonvision.local as a troubleshooting step when your IP or hostname doesn’t work
photonvision
is the hostname, so if they changed it, it would not work.
ps - I also did a port scan on the device IP and the only port that showed up as open under 10k was port 22.
Loaded 2023.1.2 on a limelight 2 today and could reach the web interface ok. Port 5800 was open.
